My '95 Legacy: Trashwagon10
Thinking of running Seafoam Trans-Tune through the system and see if it'll clean out the valves and whatnot.
Has anyone had results from this product? Good, Bad, Neutral.
  • Replies 1.3k
  • Views 204.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • TheLoyale
    TheLoyale
    Trashwagon will be making a return real soon!    I built a car created by MilesFox, only to sell it to him and then to get it back.
  • TheLoyale
    TheLoyale
    Trashwagon10 makes a triumphant return to MilesFox! We rescued the car yesterday from a kid who bought it in need of a car to get him to/from school. The outer bearing cage on the passenger side axle
  • TheLoyale
    TheLoyale
    We are The Subaru Alliance!  ____________
Posted Images
Does your transmission currently work?
If it doesn't have any problems, I wouldn't mess with it other than just a fluid change.
It works fine, other then it holds gear a little longer when its cold, takes a little for it shift outta 2nd.
Trans-Tune is composed of 3 Petroleum bases, its basically a flush to remove varnish from the valves, bands etc..
But some of that varnish might be sealing it up and keeping it working... Maybe it's just that I'm afraid of automatic transmissions. But I get the feeling with them that if they work right, change the fluid and run it... maybe someone else will chime in and say fix something that's not broken...
The 4EAT is pretty robust, Pulled 2 Subarus with it (one from Chicago)
I was mainly thinking of running it through the trans on the Legacy before trying on my Landcruiser (Which downshifts a little hard at times)
It is a very robust transmission, the one in my Legacy has 242k miles on it and has outlived two engines.
The engine in it currently is seized, which is going to make it really special trying to replace.....
*Cough* Yeah, Torque Converter bolts are gonna be a PITA to get to. ;)
I have no idea how that's going to work... I suppose when I get back to maine some day I'll figure something out, maybe do a 5speed swap while I'm at it...
Tom, slow shifts when cold are perfectly normal on these cars - mine does it too.
the colder it is outside, the longer it takes to get it fully warmed up and shifting "normally"
I know it seems a bit odd - took a bit of getting used to when i first got the Lego - but from what everyone elses says, it is normal for the 4EAT to hold a gear longer when cold.
If i let the car sit and warm up for 5 mins or so in real cold weather, it seems to shift a little bit quicker than if I dont let it warm up as long. as in will hit 4th after 1.5 - 2 miles instead of 3 - 5 miles...
as long as it is shifting smoothly when it is fully warmed up, i wouldnt worry too much about it - mine will shift so smoothly you barely notice shift changes - more sound related than actual feel.
as for tranny additives tho - there is a Lucas product out there (trans X?) that is supposed to be quite good - was recommended to us for the old Taurus (and Moms old Sable - same vintage) when it was having shifting issues (didnt want to go into gear when cold - would take several seconds to a minute to actually engage!)
i used trans tune in the 00utback, made a difference, but you would/should wanna change the fluid/filter again after driving a bit as the crap it breaks up just moves to the filter.
That would be the plan. Although I ain't dropping the pan on the EJ22 (Crossmember is in the way)
is the filter internal on those? the '00 is external. i never dropped the pan or anything, just drained what i could, i think like 5-6 quarts came out or so. dumped in the trans tune and filled with ATF, then the car got Tboned like about a hundred miles later. but the tranny was acting pretty good in the interum.
Yes, internal. External didn't start till 2000 on all Subarus.
A flush did wonders on my 97 Impreza 4EAT. and I have heard the same from others.
A fluid change made my 98 stop shifting hard into 2nd and made decently bad torque bind completely go away.
Pulling the pan isn't too bad.
Upscale Wood grain trim out of a Limited.
I always find it funny people want that stuff, I can't stand it. I just never got around to getting rid of it in my limited...
I figured it would be a joke, like Trashwagon is a luxury car lol.
Plus I pocketed the stuff from the yard anyway ;)
Is the trim in the Limited actually real wood? I have it on the window switches in my wagon and its just plastic with "wood" printed on it. Looks awful IMO. I always forget to grab some plain black ones when I'm at the junkyard though.
It's the same plastic crap of which you speak. I always forget to get it as well.
To be honest, the Limited designation doesn't really mean anything besides higher registration and probably insurance.
I don't have heated seats, mirrors, windshield. But other GT models DID have all those...
I still need one more piece, I couldn't find the one for the rear driver door. If anyone has a spare wood switch bezel for the rear driver door, I'll mail you all the black pieces to swap yours out with. (Including center console trim)
Scratch that, I need the passenger side rear switch bezel.
Fake wood is the sh*t :clap: (I used to hate it too though)
I don't think the rear got the wood trim. I really don't think my limited has it, although, I never ride in the back seat and haven't seen the car for a while.
