October 18, 201015 yr just trying to find out what year or model gas tanks will fit in a 82 Brat..thanks for the help..gas tank needed
October 18, 201015 yr just trying to find out what year or model gas tanks will fit in a 82 Brat..thanks for the help..gas tank needed non-turbo models 80-84 4wd wagon 82-87 Brat 83-84 4wd sedan the fittings/hose sizes can vary as well, but still usable...
October 19, 201015 yr Author so is a non brat model called the GL and the DL? if i was to call a junk yard, is that what i would ask for? im assuming the turbo ones are going to have different returns.
October 19, 201015 yr We put a hatch tank in a brat. wasn't too difficult, just used a steel plate ~3" across with some holes along each edge. bolted one to the tank, and the other to the mounts on the frame. Wasn't hard, but yea.....not a perfect fit. GL/DL are trim levels. there are FWD GLs that would not have the right tank, and 4WD DLs that would, or vice versa. as long as it's within the year ranges and body styles that McBrat posted, it'll be fine.
