1982gl4 Posted July 28, 2011 Author Share Posted July 28, 2011 Wiring is all done. I need to hook up my fuel pump, and program the MS, and she should be ready to run. I'm ordering wheel adaptors for the rear to get them spaced out to match the front. No word on my sway bars though calling them later today to find out where they are. I would post pics, but I have no internet at home, and wont for like another week. I'll update when I can... Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted July 30, 2011 Author Share Posted July 30, 2011 Alright so i have internet back some updates! All the wiring is DONEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!! I even hooked up my fogs I got a wide band o2, with a controller And put my better wheels back on, and got new lug nuts. This week I will be getting wheel adapters for the rear that are both hub and wheel centric, and try to get it running i gues Quote Link to comment Share on other sites More sharing options...
bigjimd Posted July 30, 2011 Share Posted July 30, 2011 It's been said before but WOW I like that vehicle! You guys are gonna force me to build a Soob of my own yet. I just wish they were a little bigger all the way around it's tough working on the daughters wagon as big as I am. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted July 31, 2011 Author Share Posted July 31, 2011 Thanks! I'll take complements any day And I agree these cars are small, but man do they put a smile on my face. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 6, 2011 Author Share Posted August 6, 2011 Some updates! Wheel adaptors are on the way I ordered them this week. My sways are in, but don't fit due to my exhaust. I'll fix it when I can get it to work after it's running I can either space the sway down, or move the exhaust. Not that big of a deal either way. I added a place for my temp sensor from the ea engine. I also finished up my fuel lines and it has a fuel pump now. I just need to wire it. after that fluids will be added, and I will then try to get it running. I just have to do some vacuum lines and then TUNE. I can't wait The rear sway! The front My fuel pump/mounting bracket using Mercedes radiator mounts and my radiator hose adaptor/ temp sensor Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 7, 2011 Author Share Posted August 7, 2011 Okay so I have all the fluids in now, and after dealing with a massive fuel leak I think I have everything sorted out. Right now I'm trying to program my MS, and I have no idea what I'm doing. There's a lot to learn here. Hopefully I can get it running in the next few days!!!! Quote Link to comment Share on other sites More sharing options...
Pooparu Posted August 9, 2011 Share Posted August 9, 2011 Where did you get the sway bars from? Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 10, 2011 Author Share Posted August 10, 2011 They are from addco. It took them a while to get to my place (a few weeks) but the kits look very well built. I contacted an ebay seller ( I think it was never enough performance or something like that) that has the them, and got the pair for $250 shipped! The front is wicked heavy, and the rear, well it will have one now hahaha Quote Link to comment Share on other sites More sharing options...
Pooparu Posted August 10, 2011 Share Posted August 10, 2011 Can you pm me the information? I'd love to through a set on my hatch. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 10, 2011 Author Share Posted August 10, 2011 Sure thing. I'll do it as soon as I can! Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 18, 2011 Author Share Posted August 18, 2011 Alright so I got some parts in today. My wheel spacers came in but the idiot that measure them, made them a bit wider than the front, but I don't think it's going to be too big of a deal. It will also help when I lower the rear, and add some RA mud flaps Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 19, 2011 Author Share Posted August 19, 2011 I'm so sick of this computer crap I've spent all day on it, and still nothing. For some reason I can't get a tach signal to my MS on it's stim. And when I tried on my car something's now wrong with the starting circuit and it won't turn over, on top of that some of my wiring's screwy so one of the relays is not getting power from or too where it should. I'm feeling rather frustrated at this point. I wish I had just cut down a stock harness it would be running by now at least Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 19, 2011 Share Posted August 19, 2011 Walk away from it for a day or two. It honestly helps to do so..... (would say go grab a beer or two, but you're not old enough) Do like the look of the tire/wheel well alignment. Don't look like the tires are "hanging out". I hates that look........ Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 20, 2011 Author Share Posted August 20, 2011 Haha thanks, I walked away from it a bit, and think I have found the problem. for some reason my Ecu isn't getting a tach in signal. It's not that it doesn't have one it's that it's not reading it. SO I'm going to be contacting Matt at Diyautotunes (for like the millionth time, I feel like I'm nagging the poor guy) , and see what he thinks on the subject. Maybe I can get this figured out.... Turns out the starter issue was a pin that fell out of a connector on the steering column that was an easy fix. And for my wiring I had the two relay out puts mixed up. So those two problems are solved. Now I just have to figure out what the heck is up with the ECU. Quote Link to comment Share on other sites More sharing options...
moosens Posted August 21, 2011 Share Posted August 21, 2011 Don't forget the alarm system. Half of VT will be following you home, and expect notes on the windshield when you come out of stores ,etc. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 27, 2011 Author Share Posted August 27, 2011 Last year was bad enough moosens, I had all of that before I did all this work, I can't imagine what it will be like now.... As for updates, I have none. I'm back in school now so progress is going to be slow. But that's not the biggest of my issues. My ecu is messed up, and I have no idea why. It can't get a cam or crank input. And the person I contact for this works monday-friday, guess when I'm at school.... So getting this figured out is going to take a long time.... Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted November 19, 2011 Author Share Posted November 19, 2011 Alright, I cracked back into this one tonight. I need to get this running for my own sanity. I brought home the snap-on modis (scan tool) from work to use its Oscilloscope function. I have so far determined that the cam and crank signals are getting to the ECU, but there's no signal to the ignitor, fuel pump, or pretty much anything else because of this. Therefor my issue is in the ECu. It's programing, or there is a problem in the way it was put together (me) I'll be e-mailing Matt at DIYAutotune so I can get this figured out. I need to drive this next summer. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted November 25, 2011 Author Share Posted November 25, 2011 For the first time in a long time I feel like I'm heading in a positive direction with this I'm getting spark when I test the MS outputs, which leads me to believe I misadjusted the VR trim ports on initial assembly. I still have a bunch to do, like get the tach signal reading, calibrate some sensors, figure out values of things like my CTS, and the flow of my injectors, I also need to figure out how to program my IAC and get that working like it should. But now that i know it has the ability of putting out spark I'm hopeful. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted December 4, 2011 Author Share Posted December 4, 2011 Spent the weekend trying to adjust the VR ports of my ecu, but got nothing I adjusted them all the way up and all the way down, and everywhere in between. There's still absolutely no output signals to my ignitor or anything else. I don't know my next move. Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 18, 2013 Author Share Posted August 18, 2013 (edited) Bump from the dead. Decided I have spent far too much time away from this, and it is time to get it running. Today I pulled a 97 legacy into the shop and tore into it. It has been freed of its wiring harness. Up next I'll be trimming it down to put into the brat. I haven't given up on the standalone, but I decided against it in this project. I may need it for my legacy more than this. Great thing about my legacy parts car is that it's a brighton, so no options, and far less to cut out of the harness. Gutted Time to dive into this again, didn't really want to start in on another harness this soon after my wagon spfi, but I feel like I should do it while i have that one fresh in my mind... Edited August 18, 2013 by 1982gl4 1 Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 18, 2013 Share Posted August 18, 2013 Yes finally!! 2 Quote Link to comment Share on other sites More sharing options...
TomRhere Posted August 18, 2013 Share Posted August 18, 2013 Been waiting for you to get back to this one....... Quote Link to comment Share on other sites More sharing options...
bratman18 Posted August 18, 2013 Share Posted August 18, 2013 You have got to take a road trip to Maine when you get this done! 1 Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 18, 2013 Author Share Posted August 18, 2013 Probably next summer I would imagine, she's got a long way to go before it's tip top, but getting a harness and ecu that I have time to work with is a big step in the right direction. I may start stripping it down tonight. And pulling the MS out. Ideally I'd like to get that to run my spare legacy turbo so I have no down time if I decide to put it in my SS. I also need to figure out rear coilovers, and an e-brake. I may go the nissan caliper root. I also need to put my new gas tank in this, and I may put a stock harness back in the brat as well. Right now it has an 84 turbo harness which has way too much going on... Quote Link to comment Share on other sites More sharing options...
1982gl4 Posted August 20, 2013 Author Share Posted August 20, 2013 Started trimming the harness tonight. Seems to go pretty smooth now that I have done another one. I still need to get the diagrams from work for the ecu power and such. Headlights, wipers, radio, heater, and other dash stuff was removed tonight. Quote Link to comment Share on other sites More sharing options...
