January 1, 201115 yr 98 outback wagon what is this light...it was flashing ...it also appears to be a button...i just picked the car up to flip thanks
January 1, 201115 yr Yes, definitely the alarm. My 98 OBW has one. You will need the key fob to operate it. Flashing light means alarm is armed. Push button on key fob to disengage.
January 1, 201115 yr Blinks to show that the car is locked and is armed. Push it to go into valet mode, I do believe.
January 4, 201115 yr It is an alarm. Someplace on the car, usually the left kick panel shold be a switch for valet mode. This isnt the kind to push for valet, i have one of those in the justy.
January 4, 201115 yr Yeah..that is the Alarm part of the 'keyless entry system'. I've had both - one with and one without. The alarm is an additional upgrade to the keyless system....there is a probably one of these under the hood: As I keep waiting for lightning to strike, I'll offer this respetful disagreement w/Nipper - the Red light is also a button....I believe the description of its function above is correct - o - mundo. And under the driver's side dash is the other button - brown (or black) - that allows the key fobs/remotes to be programmed and to turn off the alarm when the battery is disconnected>>reconnected. GL, Td
January 4, 201115 yr Yeah..that is the Alarm part of the 'keyless entry system'. I've had both - one with and one without. The alarm is an additional upgrade to the keyless system....there is a probably one of these under the hood: As I keep waiting for lightning to strike, I'll offer this respetful disagreement w/Nipper - the Red light is also a button....I believe the description of its function above is correct - o - mundo. And under the driver's side dash is the other button - brown (or black) - that allows the key fobs/remotes to be programmed and to turn off the alarm when the battery is disconnected>>reconnected. GL, Td I agree, I think that CODE ALARM used the led/valet switch but I haven't seen one in a long time. I believe it is a factory unit (added by the dealer) which I believe were made by Code Alarm with a subaru part number.
January 4, 201115 yr Blinks to show that the car is locked and is armed. Push it to go into valet mode, I do believe. One thing we have learned from Bugs Bunny DON'T PUSH THE READ BUTTON!
January 4, 201115 yr One thing we have learned from Bugs Bunny DON'T PUSH THE READ BUTTON! My 98 OBW has the flashing light alarm system. I never knew that the light is also a push button. Pushing the button does what in valet mode?
January 4, 201115 yr My 98 OBW has the flashing light alarm system. I never knew that the light is also a push button. Pushing the button does what in valet mode? The mode shuts off the alarm for the car wash, the mechanic, and the Valet incase they park the car with the keys in it.
January 5, 201115 yr The mode shuts off the alarm for the car wash, the mechanic, and the Valet incase they park the car with the keys in it. To reset to normal from valet, is it as simple as pushing the flashing red button again?
January 5, 201115 yr If anyone would like a PDF of this manual for further reading, PM me with an email address. Copied directly from the manual on my old 2000 2.5RS: The status indicator/Valet button HS1004BB The Status Indicator is a high intensity warning light, located on the dash to the left of the steering wheel. The Status Indicator displays a visual indication of the security system’s status while creating a powerful theft deterrent. LED status Off: System is disarmed. Double-Flash: System is in valet mode. Steady Flash: System is armed. Fast Flash: System has been triggered. On: System is in pre-arm state (and will arm when all doors are closed). n The valet button (built into the status indicator) The Valet Button is used to engage Valet Mode (see “Valet mode” Section). In Valet Mode, the security system will not arm, through the siren will chirp and keyless entry features will function when the security system is disarmed.
January 6, 201115 yr Author If anyone would like a PDF of this manual for further reading, PM me with an email address. Copied directly from the manual on my old 2000 2.5RS: The status indicator/Valet button HS1004BB The Status Indicator is a high intensity warning light, located on the dash to the left of the steering wheel. The Status Indicator displays a visual indication of the security system’s status while creating a powerful theft deterrent. LED status Off: System is disarmed. Double-Flash: System is in valet mode. Steady Flash: System is armed. Fast Flash: System has been triggered. On: System is in pre-arm state (and will arm when all doors are closed). n The valet button (built into the status indicator) The Valet Button is used to engage Valet Mode (see “Valet mode” Section). In Valet Mode, the security system will not arm, through the siren will chirp and keyless entry features will function when the security system is disarmed. Thanks Duania Now I just have to decipher how to shut the dang thing off...I have no fob...so when I attached the battery, the doors autmatically locked...i don't want that to happen
January 6, 201115 yr Thanks DuaniaNow I just have to decipher how to shut the dang thing off...I have no fob.. disconnect the battery, turn the key to run / on and reconnect the battery.
