Tundrabrat Build
Been getting work down around the house the last week so not as much done this weekend. Lot's of rust due to mud and moisture getting kicked up behind the fuel filler pipe.
Cleaned some engine parts... a nice break from the bodywork.
I'll be getting back on the horse this evening.
Edited by tundrabrat
  • Replies 213
  • Views 53.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • After 28 months I'm calling it done. Still have to wire the cyclops and the NOS fog lights but that is just some weekend tinkering.   Better pics to come once I get'r registered again and can wande
  • tundrabrat
    tundrabrat
    Cleaning out the garage to fit in the next project (70 Datsun roadster) and found the 50# bucket of rust I cut out of her. I had always intended to take a picture of it but then lost it in my garage
  • Big thanks to Pooparu... two tone stripes he created are awesome.
  • 2 weeks later...
Found a NOS radiator support through the Subaru dealership... one less thing I have to rebuild:headbang:
Wow! I cant believe the dealership had one Of those. Thats awesome.
Typical Ak summer... Have to stop one project (the Brat) to work on others (2 fishing trips, installing a super charger on my brother's truck, working on my boss's cabin... Etc) but I started on it again tonight and will be on most everyday for the foreseeable future.
Pics to come this weekend.
Here's some eye candy to hold you over... Ford 6.2l with a Whippel supercharger, 700 Crank HP.
  • 2 weeks later...
Torn apart ready for prep.
Por15 and welding in the wheel well... tough to make smooth welds it's pretty in close quarters.
27 years of mud and gravel required extra cutting.
Rebuilding the inside wheel well before I can put on the outside sheet metal later this weekend.
  • 2 weeks later...
Finally done welding the wheel well... there was a lot to rebuild.
Fitting a panel...
Putty has to wait til this weekend whe I get back from trip to lower 48...
  • 2 weeks later...
Cut out right rear rocker...
Formed and fitted...
welded in place...
I may have to go this route on mine. Yours turned out nicely!
What are you using to grind down the welds. I am using a flapper disc, but it is trick to blend the welds without taking too much off.
I use a cutting wheel on a grinder to get the weld down... then I use a grinding wheel to smooth it out and blend.
If you don't have a grinder I recommend purchasing one... makes life waaaaaay easier.
Before...
The rust was worse then it looks...
Rust cut out...
After...lots of new metal, now just a little bit of wet sanding and I should be good.
Before ...
After...
Finally feel like I'm getting some momentum...
Found some rust on the frame in the wheel well so I have been grinding/cutting that out. Will be treating it tonight and weld it up tomorrow.
Picking up more 18g today for the rockers, going to have the shop put in a few of the more difficult bends to save me a little time. Also picking up the final few engine bits to do the build.
Hope to have the rockers in this weekend... more pics to come over the next few days.
Man do these build threads make me grateful to have a Tx. Brat. Keep up the good work l, looks good:headbang:
Passenger side rocker
Lots of rust and dirt... Volcanic ash and snow are a bad combo.
Rust cut out... needed to rebuild the bottom of the rail
Test fitting for shape...
Rail fixed and treated...
Welded in...
Door's next...
...and this is where I set myself on fire... save your jokes (:
good work:clap:i know getting burned sucks i have a 3 degree burn on my foot and a chunk out of my hip to replace the missing skin and flesh from when i was like 2 years old or so
Thanks... luckily I didn't get burned, I just patted myself out and kept grinding.
(Insert baked alaskan joke here)
Glad you are good. Things happen when least expected. The progress looks great.
Thanks Jerry... had the paint guy over tonight to give me a little direction... working on having it ready for paint by mid September.
Passenger side rocker done... had to do a little re-shaping
Starting on driver side tomorrow...
Goal is to have the rockers done by Friday, the doors by the end of the weekend, pull the engine and have the hood and front clip finished by mid next week and have it ready for paint (putty and sanded) by 9/23.
You're lucky you had any rockers left at all, I didn't have enough left of them to patch! Your repairs are look great, can't wait to see this together :popcorn:
