October 17, 201114 yr just got these. more for shipping than the lights. http://www.ebay.com/itm/260873306056?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_500wt_1113 Edited October 23, 201114 yr by bheinen74 added wiring question
October 17, 201114 yr Need the covers for them? I have a set of the rectangular Subaru fog light covers
October 17, 201114 yr Author probably on covers. unless they come with them i am hopeful. I will have to get size measured precisely before i go for covers from someone.
October 23, 201114 yr Author did not come with covers, but did come with the switch, harness, and relay. nice score for 25 to my mailbox. now, for the mounting location on my BRAT, anybody have ideas for location to mount them? Edited October 23, 201114 yr by bheinen74
October 23, 201114 yr Author unfortunately did not come with wiring instructions or wiring diagram. On the back of the relay are 4 prongs, labeled : L B S G guessing isn't working, i thought maybe L-to lights B - battery S- switch G grounds. Anyone have similar setup that can tell me more info would be appreciated. did a temp hookup a few different ways, switch lights up when on, relay clicks, no lights. i did hook 12v directly to lights and they come on very dim with no relay but both worked. Maybe there is a "old school" Subaru service person on here who remembers working at a dealer and installing these and could direct me....here's to hoping for help Edited October 23, 201114 yr by bheinen74
October 23, 201114 yr now, for the mounting location on my BRAT, anybody have ideas for location to mount them?.... One option is to get heavy duty L-brackets from Lowes (or HD) and mount them under the Brat bumper. If you put your hands behind the bumper and feel along the inside channel, you will note a hole close to each end. These holes are not through the bumper plastic, so you will have to drill holes through the plastic on each side. You should not mount the lamps directly on the plastic cover due to definite potential for damage/deformation. The HD L-brackets will protect the plastic cover and is good support for a secure mounting. The verticle of the L-bracket goes behind the bumper. It has been several years since I did mine, so my memory is a bit hazy. If the relay is a standard Bosch type, here is a link to typical wiring schemes (see page 14). http://www.tune-town.com/relays.pdf
October 23, 201114 yr Some relays use the power feed to the relay's coil for the Common between the switched contacts. Rewire your temporyary wiring that made the relay click. Take a test light and attach one end to the Battery - you have on the relay, Touch other end of test light to each of the unused terminals to see if one will light the test light.
October 23, 201114 yr Author just fogs fogs and low beams fogs, low, high beams fogs low, high, and cyclops center light.
October 24, 201114 yr Badass I have a yellow set of those NIB. Do you know anyone who has a late model cyclops light like yours? I have an older one I am looking to sell.
October 25, 201114 yr remember, only 4 lights on at a time is the "legal" limit in Iowa I've got a set of those I just dug out to sell, but just the lights with a standard single bolt mount. no relays or switches....
