Retro GL-10 TURBO build
  • Replies 479
  • Views 153.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • a company in the usa makes them out of fiber yours looks to be the same        so
  • well the manual rack wont fit... I lowered my motor so the sti 6mt would fit and am using the longer u joint any ways when the manual rack is there i would need even a longer u joint... i have a leone
  • my guys are so busy they made mine and told me its going to be a while.. but i have another way of doing this with out costing so much which you will see in the wagon build i have going on... got new
Posted Images
Meh, those wheels are ok.  I think you should import another 4 sets of "optional" wheels so we can help you decide.
Totally kidding, those last ones are the best so far.
Some people get to have all the fun. Righteous build dude! Those wheels will look amazing!
thank you ! this is all the fun i got really but its fun when its all done and i guess fun building it to. love driving it more then building it.
LOL is that a dare ???.... one more set i need those sub zero rs ones now those are rare now days and should fit perfect on the car.
but i found something very new last night playing with rear control arms on the gl-10 !! i can wait for the car to come out now, people are going to love this mod if it really works for me..
lets just say i put those 17x8.5 235/40/17 wheels on and they fit perfect which means anything we can run on the old car, so excited to show this if it works on the real car !!
so this is a rear 1986 Subaru control arm, when adding wide wheels with low offsets like Subaru loves it can rub on the rear arm on this old car.
here you can see how much room i have to play if I put on a 17x7.5JJ ET53 stock subaru wheels that can fit Brembo brakes, also the front is not like this its normal Subaru style up front on this car so any wheel is ok
so what have I come up with ! simple easy is flip the arm around to the other side ! looks like the little Leone can put the rubber down to the ground now, 225/45/17 and i could use STi Brembo brakes now for the extra stopping power.
Hey !!!!!  why stop there ???? Lol... lets pull out a STi 22B BBS wheel and see if we can add the monster wheels on the Leone so 235/40/17 17x8.5JJ ET48  even fits !!  guess its time to show some people how its done on the track this year !
now i am really excited to pull the car out and see if this all works out perfect.
I never actually had issues with the trailing arm. My 225s rubbed on the shock body, and my 17x8 +48s occasionally rubbed on the fender
Also, are you planning on making a spacer for the other end of that piece? That would definitely be necessary to maintain the correct alignment.
It's a sweet idea for sure, but I'm a little skeptical how it will work out in practice.
Edited by Numbchux
Isn't that bushing location off center now though?  Are you going to cut the sleeve out and re-weld it in or what?  I am curious as well.
I guess it wouldn't be me if I posted and didn't mention wheels.  But I still think those 22B's would look better on a Legacy GT?!??
Edited by O.C.D.
hmmmm what brakes and backing plates are you using ? my 16x7 et53 have about 1 inch and half of space... but the 17 are way to close.. i think maybe my et53 offset is to much
a spacer if i take the nuts off ? i was just going to use longer bolts and nuts flip the arm and push out the bearing and flip that the other way also.
i want to get the car out and try it all so will see once i pull it out right now just a quick idea i had...... and now that you said the shock i think your right i will be hitting the shock on those huge 22B wheels..
1cm or 10mm thick ....  other spec i need to push out spindle from bearing so i need time.
it looks off center but i was thinking of pushing it out and flipping that also, i try not to cut and weld to much i am more a mixing and matching person first then cut and weld lol
i dont think the 22B wheels will fit like Numbchux said his rubbed on the shock, sure looks like these wheels will to !   so maybe we can put them on your legacy hehe
I was running XT6 hubs, rotors, etc.
thats what i am running which 225 on 17 specs on the wheels you use to not rub at all ? what about backing plates and rotors all xt6 stuff ? or like me
Thanks for the size, the time I have, I'll wait.
where you found hub from xt6? how much do they cost? can you send
Russia to me :)
The 225s I ran were on WRX 16x6.5 wheels, +53 IIRC. Most of the time I ran 215/45r17s on 17x8 +48s, which were Ok most of the time, but would rub on the fenders if overloaded (and my rear fenders were rolled flat).
The hub is what locates the wheel in the fender well...so it doesn't matter. But I was running XT6 backing plates and caliper brackets and 200SX calipers
  • 3 weeks later...
hmmm ok thanks for the info, got to figure this out
Russia to me :)
ill see how much it cost for them and see what is shipping then you tell me if you want to buy them off me, whats your email
well spring is near they say, but lets get real its still going to snow like today lol, so in the mail today some new toys have come in.
5x100 16x7 et46 Volk GramLights 57s.... good for maybe 225/50/16 I hope I can make it fit with out rubbing.
ST132594S000 JDM STi Magnesium valve covers.
"The STI Magnesium Valve Rocker Cover Set Impreza GD GG is a high spec part available from this exclusive company and come ready for the street/circuit/windy scene/drift. Not only significantly lightening the engine, the visual effect of having this in your engine room will surly scare any competitor who sneaks a peak under your bonnet." LOL
and the part that makes the scaring of the competitor really happen !
Borg Warner AirWerks S300SX FMW 0.91 A/R (maximum spool)  dividided twin scroll.
pretty crazy how the STi magnesium valve covers are so dark inside
also need add a air port fitting for the s300sx it was same for my s200sx, ill add it where that top bump with numbers are on top left corner.
.... I have said it before and I'll say it again... best subaru ever.   have you thought about contacting any car magazines or shows?
I personally like TUNED on the "drive" channel on youtube
just an example, but still a pretty cool car.
  • 3 weeks later...
^^  thats such a cool video and car thanks for sharing that
Turbo Seal Clamps
Constant Tension Turbo Seal Clamps - With a convoluted heat-treated band that provides spring-like tensioning effects for thermal cycling hose applications.
Murray’s unique “DUAL BEAD SHIELD” concentrates band-sealing pressure, increasing performance up to 30% compared to standard smooth liners. Flanged edges protect soft hose compounds from abrasion and wear.
when you need the best like the real real races cars !! then these are the best !
Hey Nico - I got some wheels!!!!
http://legacygt.com/forums/showthread.php/used-rims-5zigen-gn-pro-racer-take-look-them-and-204181.html
LOL
Still want yours though. :wub:
Now back to your thread.  What is the "air port" fitting you speak of on the turbo?  What are the numeric marks for?
those look sweet nice work you did to them ! there huge also lol 18x8.5 is really wide, wish i could use that stuff !
air port is for vac line on the turbo, numbers marks i have no clue but that is where i put the port lol.
i sold my wheels to a guy with the same style wagon as you, he is on the legacy board he showed me pics and i miss them but they look really freaking good on that body style !
well today was a perfect day to pull it out and start the work on the car, lots of rain wash the salt away so why not bring the car home.
my new black wheels that are so black i cant get a good pic of them lol
GC8 VOLK Rays STi 5x100 16x7 ET 53   with the proper stickers for how ever long they last lol.
also i was going to use these on my Legacy EG33 build, but ill use them here first. Whitline KSB751 will reduce rear-end float particularly under acceleration... why not fits like a glove lol
made for the new style subaru 1989 to 2007, subaru sure does love re using something that works well over many years.
Nice up skirt shot, that sway bar looks pretty beefy.
Its been said over and over, but amazing build.  :wub:
the xt6 sway bar is pretty cool since its oem 20mm back in the day old school
All i have to say is... Damn.
lol thanks
well the new BW s300sx FMW fits and is in, along with the JDM STi magnesium valve covers.
also had to take the timing belt off and pulleys so I could get to the oil feed line for the AVCS and get the screens out !.. pain in the butt but i had to get it done.
good thing I have room still for the 4" cone aem filter and set up for this turbo.
I had also changed the vacuum lines for the dual wastegates to hi temp silicone to handle the heat stress in that area.
just need to wait for the turbo pipe I ordered so I can complete it all.
and the new brakes set up with stainless steel pistons better for heat transfer on the fluid
Been a while so I may have forgot Nico but have you dyno'd this thing ever?
Oh and can I get a link to those wheels on the LGT please.
Edited by O.C.D.
no tune yet with the big turbo, it will be next week some time cant wait
ill look up and see if i can find it on the legacy board.
Ver 2 turbo pipes all made simple and silicone, with the fancy clamps. soon its time to tune this craziness.
  • 2 weeks later...
so since I am waiting for Franz to come visit and do the magic on the tune for the s300sx, I add some Hella 550 amber retro lights.
and the 1986 Alfa Romeo GTV, 86 Subaru VS 86 Alfa lol
