April 26, 201214 yr So I was checking the oil while filling my wagon today, and a thought occurred to me.... WTF does everybody do with the spare tire area after converting to a larger wheel/tire combo that won't fit? I was pondering the possibility of making a little rack to hold a few quarts of motor oil and maybe some other fluids. So, lets hear/see your ideas! :banana:
April 26, 201214 yr Well... since my Lifted BumbleBeast runs on 15" Wheels, I Relocated some things to the Spare wheel Area... Now the Spare Wheel (another 15") goes in the Back. I Relocated The Coolant Overflow Tank (Because I Needed the its Original Placement for an Extra Relay Box and Ballast for the H.I.D.'s ) and The Vacuum Acumulator Bottle, and Also I Placed an Oil Catch Can there: Kind Regards.
April 26, 201214 yr i flip a donut spare upside down and put a jug of coolant, tow cable, extra belts, and oil in it. the hood still closes and actually holds the cargo in place.
April 26, 201214 yr Author I now have engine envy Dave, thanks for sharing. I like everything I'm seeing/hearing so far, although my personal preferences don't get along with the flipping the donut idea. If I don't need/can't use it, I'm not going to carry it around with me.
April 26, 201214 yr Author Also dave, have you noticed any perceptible difference in handling from moving the weight of the battery off of the corner and closer to the center of the car?
April 26, 201214 yr the donut does serve a purpose. it becomes a ''tray'' for a whole kit of usefull things. it just happens to fit snug and doesnt require modding anything, unless you count the tiedown bolt delete. also it acts as an isulator so i know nothings gonna burn up in there
April 26, 201214 yr Author Not an acceptable trade off between weight I can't use and the limited storage it offers me.
April 26, 201214 yr the donut does serve a purpose... Yes, I Readed that it Prevents the Engine to Fell on your Lap in a Huge Fat Frontal Crash...
April 26, 201214 yr I've seen people put an air tank in there attached to a compressor. If and/or when I get around to needing a bigger tire I have also considered customizing a toolbox in that spot. I'm forever setting my tools in there when I'm working on the car anyway, so why not make it official? Or maybe some sort of nesting deal where there is a spot for oil/coolant/cables/etc, and an upper tray with a magnetic lining that would just hold bolts and nuts when I work on the motor (tools would go somewhere else). Edited April 26, 201214 yr by man on the moon
April 26, 201214 yr i would be interested to see what one could come up with that fullfills all benifits of le donut whilst weighing less. i tried a few different things (fullsize 13'' was too small in center and too tall). i also ziptie a gallon of coolant in a horizontal position near the PS strut tower (ziptie handle to ''strut tower brace''/spare rack). donut spare=not heavy (or remove rubber? to each their own. im not tryin to troll or even convert anyone (nobody said i was =) just clarifying my solution to a few cubic feet of real estate that exists in our quirkmobiles cheers, RV
April 26, 201214 yr Author I was simply commenting on the fact that I know for a fact that I could build a small sheetmetal box/container that could go in that area and hold much more, but the container itself would be lighter.
April 26, 201214 yr Author Yes, I Readed that it Prevents the Engine to Fell on your Lap in a Huge Fat Frontal Crash... Well, at least it's not that heavy right?
April 26, 201214 yr How bout mounting a small airtank there and use the ac compressor as the pump? Idk if it would power air tools but it would air up tires.
April 26, 201214 yr I once had a bad radiator and couldn't afford one for a few months so I took the A/C condenser out (A/C didn't work) and put it up where the spare wheel sits with an electric fan on the condenser then hooked it to my heater hoses. It cooled the engine very well.
April 26, 201213 yr I once had a bad radiator and couldn't afford one for a few months so I took the A/C condenser out (A/C didn't work) and put it up where the spare wheel sits with an electric fan on the condenser then hooked it to my heater hoses. It cooled the engine very well. *thumbs up* I like that!
April 26, 201213 yr I had a spare factory jack laying around and put it there. I figure two crappy scissor jacks is better than one..... They don't work too well now with the lift though. But anyway the bolt that held the spare in, also holds a scissor jack nicely. Probably going to build a cargo box to go there. Or just bolt a large ammo box in to hold some stuff. There was a time I was gonna shorten the front of the car and move the radiator up there. But that project will never happen it seems.... (Can only afford to have the vehicle down for an afternoon at a time)
April 27, 201213 yr what's with the couple people with the oil catch cans? Is this a fix for an inherent issue with ea82's? Or are their engines worn enough to blow tons of oil in the pcv system.
April 27, 201213 yr what's with the couple people with the oil catch cans? Is this a fix for an inherent issue with ea82's? Or are their engines worn enough to blow tons of oil in the pcv system. It's one of the major features of a weber upgrade, among other things.
April 27, 201213 yr Yes, and the interesting part in my BumbleBeast's Setup is that the Hose to the Oil Catch Can went too Long and Up, that the Oil hasn't reached the Catch Can Yet! ... ... but Before I installed it, there were Oil Blowin' thru the Shorter Hose. http://www.ultimatesubaru.org/forum/showthread.php?t=118239&page=3 Kind Regards.
April 29, 201213 yr Author Think I'm going to get a hold of a welder and some sheet steel when i get home from working out of town. I've got an idea in my head of building a storage box that would bolt down using the spare tire holder, and have a handle so you could take it with you around/under the car.
April 29, 201213 yr see now, thats a cool idea. it occured to me after defending my 'flip the spare' idea that had i skills and a welder, ida been in your boat. let us see what you come up with, and see if you cant get it to act structurally as well. RV
May 4, 201213 yr If you have the MPFI Turbo, like an RX you can mount a newer model topmout intercooler from a 2.5L Turbo or WRX in the spare tire area and modify the hood.
May 4, 201213 yr i flip the spare and keep jumper cables, a bottle of oil, and a smaller 4 way tire iron. my 3door is occupeid by ej22 intake tubing. I use the pare tire tray to keep bolts and wrenches when pulling motors or other routine maintenance. in non turbo cars, there is plenty of room above the passenger cv axle to keep a bottle of coolant. i also flip the charcoal canister over the intake and use its holster to keep a bottle of oil.
May 4, 201213 yr i flip the spare and keep jumper cables, a bottle of oil, and a smaller 4 way tire iron. my 3door is occupeid by ej22 intake tubing. I use the pare tire tray to keep bolts and wrenches when pulling motors or other routine maintenance. in non turbo cars, there is plenty of room above the passenger cv axle to keep a bottle of coolant. i also flip the charcoal canister over the intake and use its holster to keep a bottle of oil. I like that pulling motors is "routine maintenance" (I keep tools there when working on the car, too)
