Smiley..........
Where did all you pics go. Its-a-sayin you deleted them???????
I want to have a looky see.
  • Replies 373
  • Views 79.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Well, things are evolving again..
  • Yeah. I am building it to drive to the extreme. I have been doing extreme sports my whole life. There is one thing I learned. Wear the proper gear for the job, and you are able to do it again.
  • Thanks guys, It has been/is fun learning how to build stuff.   I have been on hiatus from this for long enough. I went and watcheedd some racing on Saturday and have the itch again.SO during this t
Posted Images
Ditto!
WElp replced the picture up front, and here are some more.
Just put the tires in front of her to see :)
Finally got my wheels welded up
Test fitting the bellhousing.I need to get anotherr Subaru hydro clutch.The one I have is from some other model i guess.Because it does nto match this bolt pattern.
Wheels all painted up, I thought I would like the whiite background.But don't.Ima change it to drab....
whipped up a twin stick setup...
Still working on the fluid barrier,
I sat around the other night with sandpaper(300 grit-ish, and 1000 grit) and polished the inside leading edges of the twin sticks to get them to move more fluidly next to each other.Then hit them with a dremel and some rouge..
The whole layout, teting bolt sizes, looking azt length etc....
Thats about it, I think I have made a deal on My Subie EJ d/r, so I will have the scrilla to throw at this thing again soon.
I need ARP studs for my knuckles, then I can put stuff together the way I want to!!
cheers
I like that you build your stuff.... I have said that before somewhere, I just wanted to reiterate the point......
I agree with this statement. Inspiring.
really?? he just makes me kinda wanna give up lol
the clutch slave has to be from like a 2.5rs style. NA hydraulic, same with the clutch fork.
I looked just slightly earlier than you posted.It is literally from 2.5 5 speeds. from like 97 to whenever that generation ends.
Got athe proper Slave, and mounted it up the trans to make sure it fit.
Then checked the fitting to the Toyota master cylinder..
Cheers:drunk:
Edited by monstaru
All mounted up .
She is sitting on her own Two feet again in the back
cheers
I got the t case lined up,the4n realized the crosmember I got for my 85 frame, didna line up with an 82?ish frame....
So , gotta remedy that....
And then remedy the front shock towers.The preliminary numbers state tthat the ford Towers are not going to work in this sitcheachin.
So , gotta deal with that...
Then we shall see what comes a knockin...
\cheeres
Edited by monstaru
DOH....evidently there is one set of crossmembers from 79-82, and 83-85.Nice.
Well,I guess I will be needing to build a crossmember..DOH!:banghead:
cheers
I have one from a 80 or 81 if that helps
It would help if you were down the road.But you're not :)
I am gonna pick up a DIY t-case plate from a new buddy down here.Should be able to make something happen from that.
cheers
My buddy & I cut his cross member in pieces to build a custom mount for his Chevy motor & trans. We used the sides, but welded in a plate for a new bottom.
Im sure you could do it in an hour... cut each end off... bolt them to the frame. Tack replacement plate in place... remove and finish.
I have a buddy down the road with a CNC plasma table.He is going to be cutting me a mount like the Front Range Offroad DIY mount.I will be using that once I get it this week.
I should have the rest of my axle rebuild stuff by Friday,including my hub gears.
Then I will be putting that stuff together.
I am looking at trading the tires I have due to them being radials.....
But with my twin stick almost done,I have alot of irons in the fire right now.
Cheers
I finally found your thread. Freaking bad*ss man!:headbang: I'm gonna have to come see it in person soon. And you gotta come see my s**t sometime soon too.:grin:
Jesse
Jesse
Totally man!I'm kinda busy at work right now,but let's shoot for beers next week.
Cheers
Edited by monstaru
Exactly what he just said.
Ill be watching this thread, very excited to see how it turns out.
Keep up the good work!
Brown Santa showed up.My front axle stuffs
I also thank Wentz for some steering arms.
giggity:-p
cheers
Edited by monstaru
Come on down!Both of ya's!!
I want to put together a "Bed Patrol" shake down run :) lol
cheers
Ok..
umm, Alright, so just picked up my hub gears.
Gonna hi"T" it hard this weekend.:lol:
cheers
Edited by monstaru
Come on Down!:cool:
i try to *hi* it hard every weekend:grin:
Did you build those decals? :Flame:
Yeah, we should make up a Saturday afternoon/evening to hang out and see your stuff.
So, I needed to add accoutrement for shock mounting in the front.
Then needed to start the shockmounts
Then I started the other side, and forgot to seat the pin on the follower:,,,,
Decided to move onto the axle again.
Fingeredd on this being the last mods to the axle before being put together.
cheers
