May 24, 201312 yr OK. I Know you guys are going to beat me for this one. But I broke the lower thermostat housing bolt, then stupidly used an ez out which broke in hole. now I have a super hard steel ez out and a really stuck bolt end. :-( what should I do? Am I screwed? I am so pissed, I was thinking about just bolting back on with the top bolt only. but I bet it would leak!!! (so close , yet so far on getting the brat back running)
May 24, 201312 yr im with him. easiest way would be a used intake manifold. make sure that the bolts arent screwed up on the new one you get before you but it
May 24, 201312 yr Naw relax bro! If you were Spokompton i'd go and help you with it so I will do my redneck best to walk you through it. The reason machine shops make so much money is because we (me included) are impatient. First of all we need to clear away, the best you can, the area around the thermostat. Then you put the small brazing tip on a torch set. If you dont have a torch set I actually did a similar thing using a small butane torch from Radio Shack. Lay wet rags around the work area. Now this is where the patience comes in. The idea is to heat up the bolt but not damage the block. Heat it up really hot then let it cool down slowly on its own. Walk away, shoot guns or something. Do this 2 or 3 times you will know when metal and the easy out is breaking down. You will need new hardened steel bits and slow down your trigger finger on your high speed drill. Slower is better in this case. Try this and have a beer. Cheers, Eric
May 24, 201312 yr Depending on How Huge is the Broken area, this Idea might be Helpful: Here: ~► http://www.ultimatesubaru.org/forum/topic/70589-idea-to-re-thread-in-aluminium/
May 24, 201312 yr Depending on How Huge is the Broken area, this Idea might be Helpful: Here: ~► http://www.ultimatesubaru.org/forum/topic/70589-idea-to-re-thread-in-aluminium/ This is an awesome thread!
May 24, 201312 yr Naw relax bro! If you were Spokompton i'd go and help you with it so I will do my redneck best to walk you through it. The reason machine shops make so much money is because we (me included) are impatient. First of all we need to clear away, the best you can, the area around the thermostat. Then you put the small brazing tip on a torch set. If you dont have a torch set I actually did a similar thing using a small butane torch from Radio Shack. Lay wet rags around the work area. Now this is where the patience comes in. The idea is to heat up the bolt but not damage the block. Heat it up really hot then let it cool down slowly on its own. Walk away, shoot guns or something. Do this 2 or 3 times you will know when metal and the easy out is breaking down. You will need new hardened steel bits and slow down your trigger finger on your high speed drill. Slower is better in this case. Try this and have a beer. Cheers, Eric I should of said intake but it is hard to type and drive on my computer...LOL.
May 24, 201312 yr You must be the guy my dad talked to the other day with the brat in the garage. He told me the color and I knew it was you, lol. That would explain why I haven't seen you drive down Josey in awhile. Hope you get it worked out. cheers.
May 24, 201312 yr Call me crazy, but i've had good luck using masonry bits on hardened bolts. Go slow, and use just enough pressure to make chips. Yes, masonry bits for drilling concrete lol Edited May 24, 201312 yr by crazyhorse001
May 24, 201312 yr If you have enough ez out sticking up try a dremel cutoff wheel to slot the top of the ez out. If you get into the surrounding metal a bit don't worry as you will have to drill and tap a bigger hole like the above link shows. Use a big flat tipped screwdriver fitted into the slot and screw the ez out CLOCKWISE. Tapping it, lube, and a little heat might help loosen it if it's stuck. Or get another intake...
May 24, 201312 yr I vote for heat the hole. Add pb blaster or yield , etc. while warm. That'll back out with vise grips. That don't work lots of us have spare manifolds. I think subaru3 has one for sale now on eBay. You can do it !!
May 24, 201312 yr Author You must be the guy my dad talked to the other day with the brat in the garage. He told me the color and I knew it was you, lol. That would explain why I haven't seen you drive down Josey in awhile. Hope you get it worked out. cheers. Yes, That's me. Were do you live? I want to see your brat some day. There are about 5 of us in Dallas now...
May 24, 201312 yr Author Naw relax bro! If you were Spokompton i'd go and help you with it so I will do my redneck best to walk you through it. The reason machine shops make so much money is because we (me included) are impatient. First of all we need to clear away, the best you can, the area around the thermostat. Then you put the small brazing tip on a torch set. If you dont have a torch set I actually did a similar thing using a small butane torch from Radio Shack. Lay wet rags around the work area. Now this is where the patience comes in. The idea is to heat up the bolt but not damage the block. Heat it up really hot then let it cool down slowly on its own. Walk away, shoot guns or something. Do this 2 or 3 times you will know when metal and the easy out is breaking down. You will need new hardened steel bits and slow down your trigger finger on your high speed drill. Slower is better in this case. Try this and have a beer. Cheers, Eric Eric, I think I will give this a shot, also the masonry bit sounds interesting as they are very hard. I already have a extra intake manifold, but i really don't want to take out any more bolts! I have a map gas torch. I will try on Saturday. Thanks for the Tips... Daniel
May 24, 201312 yr the snapon truk had a carbide drill bit for drilling out broken taps and easy out was very pricey and tech but whould do the job i drill them out to the size of the tap re for the size and retap it easy outs and taps are brittle so you may be able to shater it and pull out the peices and try drilling agian
May 24, 201312 yr Welding to broken studs or bolts if you can actually make it work does a great job. The heat and cool makes enough expansion and contraction fast enough to break most stuff free. The cause of most broken studs and bolts that I have seen is when metals are mixed. Stainless in anything but stainless, anything but aluminum in aluminum etc... really increase likelyhood of issues. Always always use anti-seize on any kind of mixed metal fastener when you put it together.
May 26, 201312 yr Author ok, used my dremmell with a diamond bit to make very small holes around the ez out, spend about 45 min messing around and got the thing to come out. then i got a cobault bit and a masonry bit from home depot, kept switching back and forth between the bits and used lots of cutting oil, about 1 hour later i have a hole that is 5/16" dia. x 1/2" deep.I guess i need to get a helicoil, I hope they work in such a shallow hole. I will try one Monday. Thanks for all the tips and motivation to attack it! I was just so frustraited and pissed! Edited May 26, 201312 yr by danrenfroe2016
May 27, 201312 yr Yes, That's me. Were do you live? I want to see your brat some day. There are about 5 of us in Dallas now... Yeah, I know what you mean, we need more people. There is a pretty cherry brown G2 Brat off of Royal Ln. I don't know if its a member or not. My Brat stays over by Scott mill and trinity mills, with my dad. Edited May 27, 201312 yr by BratRod
May 27, 201312 yr Author Yes I have seen one of royal its pretty nice. We need to put a thread on here calling all the DFW guys again to see if there are any new ones I may stop by that guys house at Royal and leave a note or something on his windshield that is real close to where I work.
May 28, 201312 yr I know I'm a little late, but I have ha this problem before so I just thought I would add my idea. First heat up the bolt and easy out and them take a punch and shatter the ez out and suck all the peices out, then drill the bolt out and use a heli coil or threadsert. This method has worked good for me. Edited May 28, 201312 yr by mikaleda
