March 30, 201412 yr Anyone have experience separating the lens from the reflector? ! have in mind custom installation of led daytime lamps and possibly a halo ring, and further possibly having the reflector plated. I am assuming to cook the assembly in an oven. Has anyone worked with ea82 headlamp assemblies? Edited March 30, 201412 yr by MilesFox
March 30, 201412 yr Nope, not a clue http://www.ultimatesubaru.org/forum/topic/120953-projector-lenses-into-glloyale-buckets/?hl=turbone
March 30, 201412 yr Somewhere on here, if I remember, was a write-up for doing a 'proper' HID setup where the poster removed the glass in order to polish out the refractor ridges (? I'm taking a guess as to what those are actually called).
March 30, 201412 yr Somewhere on here, if I remember, was a write-up for doing a 'proper' HID setup where the poster removed the glass in order to polish out the refractor ridges (? I'm taking a guess as to what those are actually called). Turbone posted that link directly above your post.
March 30, 201412 yr Put it in the oven for no more than 2-3 minutes. Make sure you do not overdo it. It is better to put it back in the oven for another minute then get it warped or get the glass cracked. assemble it back with urethane. Good luck, Sam
March 30, 201412 yr Fox, yours should come apart pretty easy as the glue is old. I have taken my old set apart to get the water out of them and to reseal them. I agree with the heat, dunno if I would stick it in an oven, a Heatgun or a Blowdryer would work well in my opinion. Then work your way around the edge with your finger tip or Screwdriver.
March 30, 201412 yr Put it in the oven for no more than 2-3 minutes. Make sure you do not overdo it. It is better to put it back in the oven for another minute then get it warped or get the glass cracked. assemble it back with urethane. Good luck, Sam Fox, yours should come apart pretty easy as the glue is old. I have taken my old set apart to get the water out of them and to reseal them. I agree with the heat, dunno if I would stick it in an oven, a Heatgun or a Blowdryer would work well in my opinion. Then work your way around the edge with your finger tip or Screwdriver. Have either of you done this before? I had no problem with mine after they sat in a hot oven for 20min. And I did this to several headlight units. The buckets are METAL and it takes a temp of 900+deg to melt glass.
March 30, 201412 yr ...The buckets are METAL and it takes a temp of 900+deg to melt glass. Yep, only Latin America, Asia and Australia got the Plastic H4 Buckets for the EA82 / Loyale. Photo of them on a EA82 Subaru: Kind Regards. Edited September 13, 201411 yr by Loyale 2.7 Turbo
March 30, 201412 yr Author I considered the oven idea. So it is 300 degrees? i was assumng lower like 125 or 150. Otherwise, i would cook them to separate them, and then i could leae them in the oven to coola down on their own before handling them if warping or breakage can be an issue. PArt f my necessirt is to cure condensation, with the opportunity to make some custom mods. Thanks for the link Rob. What you did is what i had in mind Not sure if i want to do projectors or not. I would like to ion coat (yellow) the lenses like the fog lights you see, and consider gold plating or some kind of gold coating for the reflector, and yellow bulbs with cool white led running lamp.
March 31, 201412 yr Have either of you done this before? I had no problem with mine after they sat in a hot oven for 20min. And I did this to several headlight units. The buckets are METAL and it takes a temp of 900+deg to melt glass. Yes, I do it every day of my life. Cause can't get enough you see.
April 1, 201412 yr I considered the oven idea. So it is 300 degrees? i was assumng lower like 125 or 150. Otherwise, i would cook them to separate them, and then i could leae them in the oven to coola down on their own before handling them if warping or breakage can be an issue. PArt f my necessirt is to cure condensation, with the opportunity to make some custom mods. Thanks for the link Rob. What you did is what i had in mind Not sure if i want to do projectors or not. I would like to ion coat (yellow) the lenses like the fog lights you see, and consider gold plating or some kind of gold coating for the reflector, and yellow bulbs with cool white led running lamp. You can pull the unit out after 10min to see if they will separate, but I did crack one not letting it cook long enough. Yes, I do it every day of my life. Cause can't get enough you see. Thanks for showing us how brilliant you are.
April 1, 201412 yr I agree with the heat, dunno if I would stick it in an oven, a Heatgun or a Blowdryer would work well in my opinion DON"T USE A HEAT GUN!!! Put em in the OVEN You want the entire glass lens to heat up at the same time. Heating one edge only will crack the glass. A blowdrier isn't hot enough but a heat gun definately is hot enough to crack the glass.
April 1, 201412 yr I was just simply replying to Fox with my own experience and what worked for me. It doesn't take to much to loosen the 20+yr old glue on these from my experience. Thats all.
April 1, 201412 yr Have either of you done this before? I had no problem with mine after they sat in a hot oven for 20min. And I did this to several headlight units. The buckets are METAL and it takes a temp of 900+deg to melt glass. You probably fried bacon and eggs on top of it! Mine got separated in TWO minutes. Sam
April 2, 201412 yr Author So if this technique can be used to separate the marker lens, what would be an appropriate heat range for the oven? the marker lens has condensation, and i am considering coloring the lens orange, or installing a strip led inside, plus it needs sealed anyway. I would consider the taillights, but i don't want to rik breaking them trying to remove them as all the plastic on my car is brittle. I appreciate the good advice from everyone. Tom's comment cracks me up. Not sure if i have a hair dryer, but i do have a 1949 magic chef oven
April 2, 201412 yr So if this technique can be used to separate the marker lens, what would be an appropriate heat range for the oven? the marker lens has condensation, and i am considering coloring the lens orange, or installing a strip led inside, plus it needs sealed anyway. I would consider the taillights, but i don't want to rik breaking them trying to remove them as all the plastic on my car is brittle. I appreciate the good advice from everyone. Tom's comment cracks me up. Not sure if i have a hair dryer, but i do have a 1949 magic chef oven Like I mentioned above, put the headlight in the oven, glass down, on the rack. The moisture will evaporate through the hole. Use the lowest possible oven settings. Mine got separated in about 2-3 minutes. I primed and painted the lens with aluminum based paint but it did not come out very bright. It still looks a little dull. I sealed it back with urethane that I got at Amazon for about $11.00 shipment included. If you need more information let me know and I dig up more details from my archives. Regards, Sam
April 7, 201412 yr The oven trick worked for me. The reflective bucket was kind of rusted. I tried some 'chrome' paint... didn't work very well. Headlights still suck on the '85 GL. I will go with HID when I have some time this summer. Unless somebody wants to offer to sand and polish my lens. Until then, I drive the '83 4 headlamp model. Why, oh why did Subaru stop making that? Best car, EVER. Remember to put in a batch of cookies to bake... no sense in wasting energy ... and it makes a great snack for later.
April 8, 201411 yr Author I could see painting the reflector if projectors are used. I could go ghetto-gold for the effect, but that would be too ghetto for this car. Blackout could be a consideration with a projector beam, and perhaps eyelids as well if the reflector is not necessary for the projector. maybe some kind of gold foil like you see on intercooler wraps and such.
