1994 Loyale 4WD Transmission Swap Automatic To manual
I just bought a 1994 subaru loyale 4wd 5 speed..  It came with a parts car, 1993 loyale 1.8, but automatic tranny (the tranny is blown, hence its a parts car).
However the parts car has a body in much much better shape (it doesnt have any of the typical subaru rust).
My question is, is it possible to do a engine and tranny swap from the driver car to the parts car?
I'm very mechanically inclined and it definitely looks doable, I'm just wondering if it will jive or not.
Thanks for any help!!
yep Ive done it, everything bolts in, trade out
pedal assembly with pedals and clutch cable
transmission with crossmember and shift linkage
inner plastic
the wiring will be different
I've heard you have to fabricate your own carrier bearing for the driveshaft but that might only apply to going from front wheel drive to four wheel drive so.... I'll be quiet now..
