1997 outback 2.5 suddenly running poorly
i'm picking this up tomorrow and wanted some feedback on possible causes.
PO states the car just shut off one day. no loud noises, overheating or anything it just turned off. he had it towed home and was able to start it when cold but it now runs very rough. he replaced the coil pack, and "a bunch of sensors" but it didn't clear it up so he bought another car. smoking a bit out the back but not terrible (oil smoke) and no pressure in the coolant bottle.
any thoughts?
thanks in advance
G
i'm usually suspicious when someone has a non or poorly running car and has tried work/parts like that.
timing belt - broken, jumped, tensioner or pulley failed and compromised timing
MAF sensor
Cam/Crank sensor
Fuel pump
Cylinder misfire (plugs, wires)
Idle Air Controller
  • Like 1
AT Temp light working normally.
Coil wire not changing things can be a burnt valve.
How many miles are on this?
Is it possible to get the old parts that he replaced and put them back on? When people just start replacing a lot of sensors they can make things worse or impossible to solve.
234k
he included the old coil pack and a couple other parts i didn't look too closely at.
What's the idle rpm roughly? Not sure if this is relevant but just mentioning it since it comes to mind re: the unplugging #1 plug wire. I remember an old EndWrench article said something about if for some reason the ECU doesn't think it can reliably control the idle RPM, it will cut the #1 injector pulses.
Running rough, lets start with the biggest PITA unfortunately, the plugs. DO a wet and dry compression test and lets go from there. At 234K miles even if it is a burnt valve, I wouldnt recommend on repairing the engine, but rebuilding it or replacing it.
leaning toward a 2.2 swap. any thoughts?
  • Like 1
Lots written on this forum about swapping in a 2.2 into a 96-99 Legacy. Just search around and read a lot. I swapped in a 95, 2.2 as a direct drop in. Car runs great.
this was what i had been told. want to find a lower mileage 95 motor close to here (had a wrecked one w/ 105k on it but i fixed it instead of parting it). i will search, read and ask questions once i find one. i really think this motor is gone
Well lets not jump the gun just yet, do a little more diagnosing first.
you're right but i saw a lot of oil smoke coming from under the hood when it warmed up, has ZERO power.....it literally would not make it up on to the deck of my rollback.
90-98 will work.  the 90-94 will require you to put a 95 intake manifold on and work around the EGR if your engine has one.
good to know. probably will try to find one i can just drop in. btw, i was just reading your fs posts with the details of your accident. i pray you're on the path to restoration
