What year outback struts to lift my 99 LGT?
Just bought a 99 LGT and am looking to lift it. I know I have to throw on outback struts, but I don't know if I should be doing the same year or a different one
One thing is to check what type of rear suspension you have. Multilink started in 2000 but I thought I saw somewhere that some late build MY 99's got rear multilink too.
No need to check it, the legacy didn't get multi link until the 00 model.
2000-2004 fronts work just fine but not the rears.
98-04 Forester will give you just a little more lift if you want it. front and back are bolt in.
Edited by AdventureSubaru
It's the forester springs that give the extra lift over outback. The front struts are identical heights for 98-08 forester and 96-99 outback (probably 00-04 as well). The rear struts from the outback are taller from knuckle mount to spring perch by about an inch, this only applies to the 96-99 vs 98-03. I have posted pictures in a couple other threads showing the difference in these.
98-02 Forester is one style. 03-08 is the same but has a higher rear spring perch. But all 98-08 will bolt in.
So just grab some 04 fozzy struts to lift?
Again, 98-08 forester struts will work, but the 98-02 have a lower rear spring perch so you can't fit as big of a tire. 03-08 have a higher rear spring perch that allows a bigger tire, or 96-99 Outback would work as well.
Edited by bratman18
Alright, thanks for the help!
