Dropped an allen wrench inside transmission!
On my loyale some one before it came to me had the check engine light rewirered to the altornator light it comes on then you turn the key on and goes off once running like its saposed to they took the wire off the check light and ran a second wire from the alternator light very easy to do and to get to on my freinds car it was a auto but now its a manual and someone wired in a relay to fix the nutral safty switch i dont have any idea how it was done but i know it can be done
  • 1 year later...
can you jumper the connector with a wire?
it's not a "neutral safety switch"
Neutral switch on MT subarus HAS NOTHING TO DO WITH STARTING
And to the OP......If part 30 in the upper diagrahm is broken, you are going to get stuck in 4wd at some point.  Possibly even stuck in 4 low.  That is the 4wd shift collar and has several interlock pins inside to grab and let go of the lo range rod.  Happens when the 4wd shift rod rotates while being pushed in/out.    Plan on needing to replace that fork.
Good thread dig from 2016!
Maybe they’re stuck on the side of the road somewhere with a jammed gearbox waiting for help? :lol:
Cheers
Bennie
Cheers
Bennie
dang it
gotta remember to look at dates on these
