One Red Ride Posted June 11, 2004 Share Posted June 11, 2004 Sorry to bother you guys with a stupid question, but I'm trying to help out an elderly neighbor. I want to change her fuel filter on a '92 Loyale. Do I need to relieve the fuel pressure before disconnecting the underhood filter? I know on Fords, we trip a fuel shut off switch in the trunk and then run her dry before removing fuel lines, but I'm unfamiliar with the Subaru. Is there some trick to accomplishing the same thing here? Is it as simple as pulling a fuse or something? Thanks in advance for any advice. ~Steve Quote Link to comment Share on other sites More sharing options...
calebz Posted June 11, 2004 Share Posted June 11, 2004 You can pull the fuse, but the FSM actually says to unplug the pump and run it dry I think.. The pump is under the car right in front of the passenger rear tire. theres a little two wire connector.. pretty easy. In case you don't know already, the fuel filter is mounted right behind the front drivers strut tower. Welcome to the board. Quote Link to comment Share on other sites More sharing options...
86subaru Posted June 11, 2004 Share Posted June 11, 2004 i took a dry rag and put it around the old filter , and unsrewed the clamps , very little gas came out , please do not smoke while doing this and you might want to do it outside on the gravel . make sure you put the the new one on the the right way Quote Link to comment Share on other sites More sharing options...
Aussi Vortex Posted June 11, 2004 Share Posted June 11, 2004 I have had PLENTY of fuel problems... with being fuel injected, it is like a water pistol untill the pressure is releaved. Use the rag over the filter - a big one! Even a carbie model holds pressure and there is no bleed off that I have found. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 11, 2004 Share Posted June 11, 2004 for carb models, I use some "hose pliers" they are orange, and squeeze the lines to stop the flow (without damaging them). they have a "stop" piece on them that allows them to be locked into the closed position. before getting these, I always used a vice grips very carefully to stop the flow..... Quote Link to comment Share on other sites More sharing options...
subyrally Posted June 11, 2004 Share Posted June 11, 2004 at the shop i worked in, all we did too relaive the pressure was open the fuel cap. nevr had gas spray out or leak more than it should. its not complicated at all Quote Link to comment Share on other sites More sharing options...
