December 5, 20178 yr Hi guys I have a ea81 and I want to run a 50 shot of nitrous don’t know a lot about nitrous yet but want to know if it would be safe before I invest a bunch of time the engine has 150k miles on it and I plan on driving it home afterwards thanks for the reply’s in advanced
December 5, 20178 yr Make sure you can get lots of parts. But not a good idea. Not sure how available parts are for these old engines.
December 5, 20178 yr If its not been done before we need you to do this and record everything to here, YouTube and Facebook. Not too much that could go wrong surely?
December 6, 20178 yr Giggle gas is never safe. Even when handled by "professionals". You see cars go up in flames and throw parts halfway across the race track even under "professional" use. The least that will happen is that you will yardsale that poor EA81. If you are unlucky you might also set yourself and the car on fire. GD
December 6, 20178 yr +1 At 150K, it's a bad idea. On a fresh engine, IF you studded the heads and had an ignition control system to run the timing along with methanol injection, it should be ok with a 50 horse shot. The engine will surely yardsale under current mileage and configuration as GD pointed out. You can't build power from an EA81 without knowledge and experience, and even then, you're still limited by original design.
December 9, 20178 yr Nitrous is cheap power. If done right. You must have the proper ring gap, timing and wet system. Or you'll just blow it. Plus, with the small displacement, low compression and lack of fuel, 50hp shot would be more like a 10hp shot.
