Starlite,
One has to assume that "under the steering wheel" means up under the lower dash where the steering column emerges.
While I can't tell you specifically what the one connector is supposed to be connected to,I can tell you that it most likely is not going to be an issue. It really comes down to "do you have any dash or steering wheel mounted options that aren't working"?
If everything is working as it should, the connector is most likely not connected to anything, because its for an option that you don't have installed on your car. Car manufacturers frequently have just one wiring harness made up for any particular model, that contains all of the connectors for all options. But in base models, and mid level models, some of the connectors lead nowhere because the heated steering wheel option, etc. is not sold on that particular model, so the connector remains empty.
I suggest just crawling under the dash, and if you can't find the mate connector (it'll be the same colour of wire and will fit the connector perfectly) then just tape or zip tie it up out of the way.
Over the years I've installed power seats in cars that didn't come from the factory with them. The wiring harnesses for the power seats were hidden under the carpet, and when I located power seats from a wreck, I simply plugged the power seat connectors together and had the seat option work perfectly.
sorry but no - those green connectors should NOT be connected for normal daily operation. They are test connectors used to test relays and such.
and unless I miss my guess, the white ones are also test connectors - on older models they were black.
Neither should be connected for typical daily driving.
They don't typically cause problems if plugged in, but they really should not be left plugged in.
  • Like 2
And that diagnostic mode can be quite useful!
Use them frequently to check fan and fuel pump relays, etc. VERY useful. All manufacturers should include this feature. If more people were somewhat electrically savvy they would be able to diagnose on the side of the road. And they would know better than the try to fix it when it's not broken. Can't tell you how many times I've seen people plug those in just because "it doesn't look right disconnected". Keep your grubby little hands off the inner workings of your vehicle if you don't know what you are doing!
Edited by GeneralDisorder
