EA82 will this oring work for big metal radiator hose?
Thanks again Dave, that makes sense and I'll give that a try also.  Hindsight "is always 20/20" and you told me right  from the start - "replace ALL 7 hose and this Oring.."
When I woke up today I thought about how hard it is to physically measure something that has angles, distortions and curves and is rubber like - using a micrometer. So I weighed them on a digital gram scale and AT FIRST the old one weighed a little more (1.4 vs 1.3) - because I had just washed it with soap & water and dried it quickly with my T shirt...  Well I figured maybe water is still deep in the "micro cracks" so I "roll snapped" it between my thumb finger a few times and then it weighed 1.3, same as my new candidate.
Then I remembered I didn't throw out the old pump (it was working fine..., but replaced) and I thought I'd look into that hole WOW! That is probably why no matter what I did I could always hear bubbles in my water system when driving - REALLY AMAZING to me THAT this old motor kept "humping along" this long! Also glad overall that I had used Barr's Stop Leak (and almost 2 years earlier "Prestone AS663 Head Gasket Stop Leak with Kevlar" which had been completely flushed out a year ago ) and I seem to leave a white powder build up wherever there was a leak.
Stupid joke of the day -- "Do ya think this was sucking air and leaking?"
IMG_20181110_135150_edit.thumb.jpg.e2c3d1da10b4d269fedc0414cdcaf236.jpgIMG_20181110_135142_edit.thumb.jpg.483b6707453f621fe96a55aee9085668.jpgIMG_20181110_135138_edit.thumb.jpg.f829df2f842becf4d02abb2644dd29d7.jpgIMG_20181110_135131_edit.thumb.jpg.e26bc1aeb3bd4ba020278e8e10879bcd.jpgIMG_20181110_135123_edit.thumb.jpg.4cca0ff23c86ec781ce7793496d4550b.jpg
Edited by Craigar
The new one I fished out of and Autozone assortment ended up feeling tighter than what probably was the stock replacement that czny sent me,which measures .115 in thickness with a micrometer .  The old flat one was just slightly tight. I figured the thicker one might be safer with my old metal pipe cause it took a fair amount of filing to get it to where it was half clean metal again. I probably really ought to get a new pipe!
filed..
steel wool lassoed, back & forth about 30 times
here's the other end (rubber hose from bottom of radiator goes over it) - I think I REALLY ought to get a new pipe - (or maybe a new car)
Edited by Craigar
  • Like 1
With those pits, either a new pioe, or a thin layer of rtv in the groove.
With smooth surfaces, I have found that plumber's silicon grease works well for helping seal, and when you have to remove, the hose is not stuck to the nipple.  Also I have used it on the oring.
Coat a new o-ring with some RTV and you will be fine.  I did mine in 2005 and it is still holding (fingers crossed!).
Good luck,
Sam
  • Like 1
