1983 GL Wagon build thread
Neat trick on those spoilers we didn’t get anything like that here!
When you say your 1000-1500 out with your engine swap, are you talking about an EJ22 swap? And is that the money you’ve sunk into the project already, or the money you need for the conversion?
Once you’ve got an EJ in there and you keep the maintenance up, it’ll look after you. Mine is SOOO much better in every department compared to the EA82 - but that’s not hard to do either!
Cheers
Bennie
  • Replies 126
  • Views 19.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • 83subaruGLchick
    83subaruGLchick
    This is the day I first bought the GL. Bought it with 375K miles on it. Unsure if the the original motor or trans all I know. Is it is a 4 speed dual range and an EA81.
  • 83subaruGLchick
    83subaruGLchick
    And another from that weekend.
  • 83subaruGLchick
    83subaruGLchick
    This was the other day I drove it up a mountain we have here called Peavine. I flexed her out a little sadly the tire got so stuck in the front fender. I have big plans for this car I should be buying
Posted Images
Cheers
Bennie
Yeah I’m talking about an EJ22 swap. That’s about how much more I need to spend. I still need to buy the flywheel that’s drilled out and wire trimming from SJR as well as the exhaust which I’m planning on custom making headers back for that so that won’t be too bad. I already have everything else needed at this time I believe
I’m also getting really frustrated with the lack of information on these cars about the lifts. I’ve never lifted anything like this I’ve only ever lifted trucks and when you buy those lift kits they come with instructions and tell you about additional parts you need to buy. My lift kit although great quality from SJR came with absolutely no instructions, luckily I figured out what pieces go where but now I’m stuck again because I’m trying to find front brake lines that’ll work because stock ones are way too short and the rear Rancho shock that SJR and ADF say works I bought and it doesn’t even bolt right up either. I need redrill the upper mounting holes on the shock to make it fit. I don’t know if anyone else has had all these issues or if it’s just me? I’ve tried to search on here for answers and I haven’t gotten any. I WILL do a full write up on this lift kit once it’s completley done so it’s out there for everyone so no one has to deal with the crap I have had to. Anyone have any advice? I’m not a beginner wrencher either and my friend that’s helping me has built crawlers for 10 years and has NEVER seen the spoob I’m dealing with. Cheers guys!
I have the SJR 4 inch lift picture instructions on DVD. These were for the older all folded steel lift components but should be what you need.
I'll make you a copy & send it if you PM your mailing address.
Front legacy brake lines might work. I’ve heard of ppl using these on their L series when lifted.
Or try forester front lines ;)
Cheers
Bennie
Cheers
Bennie
Thank you for this it’s something so obvious I seemed to have not even thought about it. I will be going to a local auto parts store today.
The rear end is all together and DONE :banana:
only thing I need to finish the lift is front extended brake lines which I’m going to order today.
I used a Rancho RS7241 shock for the rear which is supposed to just be the better quality of the Rancho RS5241 ADF and SJR suggest  I did have to drill out the upper mounting bracket on the shock to fit my bolts though they where too small  AB4C2C72-CF14-4177-A6DE-71EE42262FD0.jpeg
Edited by 83subaruGLchick
And here’s the front end. All cleaned up and together only thing missing is the extended brake lines and I also have to make the extended steering shaft. Other than that we are finally almost done! Take about a long time coming.
So just to do a quick summary of what I’ve been doing to this car since January I have replaced the following:
Front passenger side e brake cable
Front rotors and pads
Front brake lines
Inner and outer tie rods
Ball joints
Rear shocks
Front struts
Front CV axles
SJR 4 inch lift kit installed at the same time
This whole process has taken a lot longer than anticipated and it’s partly because I swear for a minute it seemed every old part I touched needed replacement as well as waiting for parts to come in, needing money for the thing and so on. I also cut the fenders sanded/cut a ton of rust off and painted the fender wells and around the wheel wells and rockers.
These where the solution to my front brake line mishap!! These are in they are working and they’re gorgeous. More pictures to come from today!
The lift kit is on! Just gotta finish extending the steering shaft and shorten the bottom radiator hose then I could drive her. :clap:
1 hour ago, 83subaruGLchick said:
Brake lines in and bled :brow:
Everything looks great!
Get some wiring harness spiral wrap at Homeless Despot or auto parts store & wrap those brake lines to protect against flying rocks. ;)
1 hour ago, alexbuoy said:
Where did you get those brake lines
I just sent you the part numbers. But I bought them at summit racing.
STI brake lines fit the front of any EA81/82 series car (not sure about Gen 1s though).  I can also confirm that STI rear brake lines bolt onto EA82T/XT6 rear disc brake calipers (No idea about fitment to drums), just make sure the caliper is clean where the copper washer will seal against the outer body of the caliper casting.
WRX brake lines also fit but if memory serves me they are longer than necessary, but don't quote me.  Measure your stock lines, then look up the specs for the STI/WRX lines and make your choice.
Edited by carfreak85
Update time yet again!
I just wanted to also say thank you guys that follow this and like my build it's awesome to see that although I'm mostly posting here for myself some people actually like seeing it as much as I do!  Okay so onto the updates, the steering shaft is in and extended I also replaced the crankcase breather hose because I went to move it out of my way and it just broke into like 10 pieces.. also had to get a longer vaccum hose from the intake to the brake booster due to the lift and shorten the lower radiator hose due to the lift as well!  I started her up last night in hopes of moving and driving her but I cant get it into reverse due to it hitting the body around the shifter so I'm just going to hammer it out a little and put the carpet back over it and you won't even be able to tell.  I figure while I'm there I'll probably due that 4 speed slop fix that I saw that involves self tappers...
PICTURES TO FOLLOW! ONCE AGAIN THANKS FOR FOLLOWING THE BUILD.
Self tappers used in the slot and bolt trick? I’ve not heard of that.
What I did is probably what’s documented in the threads above: remove the tube piece with the ~45* angle bar on it that goes to the lever pivot.
Grind/cut a good slot in the tube, perpendicular to the bolt holes so that the slot goes beyond where the holes are. I cut my slot to be about 3mm wide.
Replace on the vehicle then drill the hole out to a larger size, this includes drilling the gear selector rod. Have a bolt that matches the hole size.  Place the bolt in the hole then do up the nut as tight as all buggery!
A lock nut will work well for this job.
You’ll feel like you’ve got a sports shifter once this is done!
Cheers
Bennie
Last night we cut and welded in the new 4wd linkage for the lift.  Just gotta go home after work and put her all together!!
So car is all back together reverse works! 4 hi and low work! Went to pull it out of the garage and it made it to the end of my driveway and the front driver side axle which is brand new broke into 2 pieces. I don’t know why this happened because the lift doesn’t change the angles I think it was just a defective axle or something. Anyways I’m going to have to take that whole side apart again and replace that axle but I’m honestly so frustrated with the car it’ll probably be a while before I do that. Also the transmission is leaking pretty quickly and it wasn’t doing that before either, not sure what’s going on there.
Here she sits. She will be sitting on the street for a while here in a little bit too because my roommate needs the garage for his Toyota crawler he’s gotta do some stuff. Would’ve been done if this car didn’t fight me every step of the way.
PM sent.
Shame that had to happen. Everything was shaping up so well for you.
Edited by czny
Don’t give up on her yet! You’re bound to come across some issues along the way!
I’ve wanted to burn mine a few times, I even lined up a better body but I couldn’t bring myself to doing the swap. That was about seven years ago now. She’s still kicking and loving the offroad stuff!
Cheers
Bennie
