CV Reversal
Folks,
Brand new here.  Found the site by accident while looking for repair / replace info for Subaru Forester CV joints.  Hoping maybe I could lube them up and save my wife some dough.
I found an old thread about reversing the axles to put the load on the other bearing face that normally doesn't see the high forces.  It sounded promising but I couldn't connect to the links from back in 2010 or whenever it was.
Is this a valid 'fix' for a 2010 Forester 2.5?  I'm reasonably capable with tools and would undertake it if there is some supporting evidence...
Thanks for your feedback.  Sorry I couldn't locate it in earlier questions.  Probably didn't go back far enough!
Best,
Rob
Get a CV band tool if you don’t already have one
Cheers
Bennie
you might consider grabbing an extra coupla bands.
I discovered it's easy to break one if you've never used the tool before.......
Just wanted to thank you all for your feedback.  Gonna give it a go!
Keep 'em rollin'!
It's an interesting theory. But to me, it seems that if the surfaces in the joint really are that worn, it's going to be a problem either way.
That said, I've brought some really troublesome joints back to life with new boots and grease. I've never bothered to swap side to side. I just re-boot originals.
