I have a throttle position sensor error, P0120.  After the engine warms up the engine will eventually start to hesitate and then surge, as if I was taking my foot off the accelerator and then pressing it again.  After a bit of surging, the check engine light comes on and I can read the P0120 code.  Warm or cold the engine starts and idles fine.  If I clear the codes and drive some more, the surging and TPS error will return after a bit.  It never happens until the engine has been warm for several minutes.
I replaced the TPS and the problem didn't go away, so I don't think it's the sensor causing the TPS code.
Does anyone have any recommendations for what else I should try?
Share this post
Link to post
Have you cleaned the throttle body yet?
Share this post
Link to post
No.  How do I do that?  I have a couple cans of carb cleaner at home; can I just spray some in there while I rev the engine?
Share this post
Link to post
I cleaned the throttle body as best I could, no change, still have the same intermittent problem that only shows up once the engine warms up.  I can't clear the P0120 code until the engine cools down.
I removed the connector from the TPS, and the center pin shows 4.6 Volts.  Should that be higher?   Obviously, it's the three pin TPS.
The new TPS shows about 5kOhms resistance between the outside pins, and the center pin to outside pin resistance varies smoothly from about 60Ohms to 5kOhms.
I found a couple threads on how to clean the throttle body.  The instructions varied from ``Don't even try, you'll ruin it!!!'' to ``Spray it with Gumout.''  I cleaned it inside with a rag moistened with a little WD40, until I couldn't get anything more out.  There was definitely a lot of carbon in there, but only a thin coating, not thick piles of crud.
Share this post
Link to post
My guess is the TPS is seeing it's fully closed value when you are at light throttle.  I think this type has an initial "fully closed" switch built in that goes to ground when at idle, off throttle entirely.
If that switch portion is closing too early, this causes the ECU to cut fuel for engine braking, then as you begin to press the accelerator a bit more in response to slowing down, you open the idle switch in the TPS and fuel kicks in again.
Try the adjustment procedure for setting the TPS idle switch "fully closed" position.
Share this post
Link to post
OK, that makes sense.  Where do I find that procedure?   I have downloaded a factory service manual PDF, do you know where that procedure is in there?
Share this post
Link to post
FerGloyale, mine is the three pin TPS.  Is that the kind you're talking about that has the fully closed switch?  Can you point me to a description of the procedure to set it?  I still haven't found that.  Also, do you know if that 4.6V open circuit reading on the center pin of the connector is OK?
Share this post
Link to post
http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1996/Service Manual/ENGINE SECTION/ENGINE/
second pdf from the bottom (ends in 5971) is a diagnostic table listing the most common to least common causes of various issues.
Perhaps you should take a look at that. The symptoms you are describing could have multiple sources, including bad vacuum lines, a cracked (or poorly connected) air intake tube, etc
  • Like 1
Share this post
Link to post
Thanks, heartless.  I was able to retrieve that from http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1996/Service Manual/ENGINE SECTION/ENGINE/MSA5TCD96L5971.pdf
It does look as if a vacuum leak is a likely candidate for surging and hesitation.   The throttle position sensor that I keep getting a code for doesn't even show up on that chart.  The TPS is new, and its resistance measures OK, so I don't think it's causing the code.
I have a vacuum gauge.  As I recall from carburetor days, if the idle vacuum is low, or fluctuating, there is a significant vacuum leak.  Does it work that way for fuel injection?
Share this post
Link to post
pretty much, yes.
old, dry vacuum lines (23 yrs old) can easily crack, or just not seal well any more. Good practice is to get some new line in various sizes and replace everything you can get at. Not that expensive to do and frequently will solve those "head scratcher" issues. There are a few smaller sections that can be a bit of a pain to get at, but they are entirely do-able with a little patience and perseverance.
Share this post
Link to post
I got a scan tool, an Autel AL629, and looked at some data.  What I found is that the TPS reading jumps about wildly while the engine is bucking and surging and hesitating, and drops to a steady zero once the thing stops misbehaving.  Unsurprisingly I now have a P0121 TPS range error as a stored code, along with the P0120.  My best guess right now is that I have a bad connector or broken wire somewhere in that circuit, and when it makes contact and the signal gets through it's all noise, and when the broken wire isn't making contact at all, the circuit reads zero.  I plan to test that hypothesis by disconnecting the TPS entirely, and driving for a while to see if that intermittent problem returns.
I haven't put an analog vacuum gauge on it yet, but the scan tool shows that manifold pressure responds as expected to throttle operation.  The scan tool probably wouldn't show the flutter that could show up on an analog gauge, and I should get my old analog gauge on there.
Share this post
Link to post
you also try temporarily adding a ground connection from the TB to a good ground - and look around for ground points to refresh....wire brush every side of every lug, the body/part, the little screw, etc. - then reconnect and maybe coat with dielectric grease.
Share this post
Link to post
just a spit ballin here, but i had a honda civic that did the same thing, similar CEL code... turned out the fuel filter was pretty clogged up, sooo changed that, fixed the problem, light went away on its own after a couple hundred miles of driving.
So, i would guess checking your fuel system if your current line of investigation doesnt lead you anywhere.
Share this post
Link to post
Thanks.  I should have said in the original post that I did replace the fuel filter and test fuel pressure early on.
That is an excellent thought! I'm accustomed to AC power, and I don't have the habit of thinking about power flowing through anything but wires.
Share this post
Link to post
I also am in the habit of re-connecting connectors on occasion, in case a fresh 'wipe' of the contact surfaces removes some minor voltage drop.
the ecu and all the sensors. solenoids, motors, etc. make the modern car as much an 'outdoor' computer as a vehicle.
doesn't mean it will solve the present issue, but is cheap and easy to try.
Share this post
Link to post
I tested the resistance between E13 pin 1 and ground, got 136 Ohms.  That's obviously bad, so I found the other end of that cable at the E2-B21 connectors.  There are three engine-bulkhead connectors mounted to the passenger side of the engine, down low.  E2-B21 is the 12 pin connector in the middle of that stack.  I unplugged that one, and put on a smear of dielectric grease before I re-plugged it.  Then I read -5 Ohms.  I figure the negative resistance indicates there is some stray voltage, but I'm not going to worry about that yet.  I plugged the connector back onto the TPS and took a test drive.  Same problem!
On 6/27/2019 at 10:02 AM, FerGloyale said:
My guess is the TPS is seeing it's fully closed value when you are at light throttle.  .
Now that I have the scan tool , I could check that, and it was indeed the case.  I probably was at 1/8th throttle before the TPS value got off 0%.   With Key On Engine Off I twisted the TPS until the scan tool reported the smallest non-zero value I could manage, about 0.4%.  I drove about 50 miles and I think it's fixed.
  • Like 2
Share this post
Link to post
Not fixed at all!  The problem is intermittent, and it's back.  As before, the live data shows the TPS value falls to zero (the gas peddle is depressed and the throttle is definitely open) and then it jumps back up to a correct value, causing a surge.
I'm back to suspecting a bad wire or bad ground.  For now, the engine runs just fine with the TPS disconnected, which means the computer is getting a 100% reading.  We can live with that for a while.
  • Confused 1
Share this post
Link to post
Create an account
Register a new account
Sign in
