February 1, 20206 yr I am pretty sure I am having a fuel pump issue. Driving down the road at 55mph and the engine just cut off, no fuel. Wouldn't start back. Pulled it back to the house and removed a fuel hose to the carb/EI and as suspected, no fuel. The issue is, I had ordered what Rock Auto said was the replacement fuel pump ($39) and it looks nothing like what is on mine. Scouring the internet for ( SPECTRA PREMIUM SP1319 - $255, also looks as if it has to be manufactured, b/c delivery date is 1-2 MONTHS- looks the same as mine. Are people adapting a different pump instead of using this very expensive replacement?
February 1, 20206 yr Someone may have a spare. Also check with any local boneyards. Some people have reported using a fuel pump from an old F150 pickup. You'll need to search this website for more info. Good luck
February 2, 20206 yr Author the fuel injected thing is weird. yes and no. looks like a carb but has electronic parts. kind of the crossover years
February 2, 20206 yr Look it up on www.carid.com They list both carb and fuel injection. Fuel injection will be 22 psi and carb will be like 4-5 psi.
February 2, 20206 yr Airbox to the side or airbox centred on top of the engine? If centred on top of the engine, it’s a carb. If on the RHS of the vehicle it’s EFI. Single port or multi port it doesn’t really matter. Cheers Bennie
February 3, 20206 yr 89 is Injection not carb. Likely SPFI which was always good to me back when I had too many of those cars. What happened to Walbro ? Do they still have pumps for the old EA82? They sure used to. See if any if this nonsense helps you. https://www.google.com/search?q=walbro+fuel+pump+subaru+loyale&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
