05 LL Bean Outback - Not charging
Batery/altertnator outputs easy to test.  I'm thinking maybe the problem is the alternator is not being spun fast enough.
Edited by john in KY
or maybe a bad  replacement alternator.
Too bad they didn't give one extra detail, "charging problem" is ambiguous.
Normal wiring issue (connection, wiring, cleaning) or bad aftermarket alternator are most likely without knowing anything.  If a competent shop didn't do the work there's no telling if it's just something they're doing or missing.
In the past there were numerous complaints of aftermarket H6 alternators not working properly.  But identical symptoms two alternators in a row? Seems unlikely.  unless during the first repair attempt they replaced the battery and alternator at the same time so to speak and they fixed the original charging problem but introduced another one - which the newest alternator mimmicks, because it's no good or not H6 compatible.
The H6 alternators have a reference signal from the ECU.
Edited by idosubaru
Thanks for the feedback.
