kanurys Posted November 2, 2020 Share Posted November 2, 2020 Hi everyone, It's been a long time since I posted. I have been hearing a clunk that has been getting worse over time. The other day i got under the car and shook down the drive line to find the rubber around the support bearing has been mostly chewed up. I searched high and low for a proper part number or instructions for replacement for this specific vehicle, but with no luck. Does anyone have any direction on replacing this bearing on our cars? Does anyone have better searching capabilities than me for a quality part? Here's a video I took when I noticed it: This GL has a 4" lift and an EJ swap. I will be making a better bracket to drop the bearing mount when I pull the drive shaft. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2020 Share Posted November 2, 2020 This is where you have a single piece driveline made. You can't get any of those parts anymore except from the junk yard, nor are they appropriate for your lifted chassis and higher power level. GD Quote Link to comment Share on other sites More sharing options...
kanurys Posted November 2, 2020 Author Share Posted November 2, 2020 I was affraid someone would post this. Of course its GD... It might just be better with a single piece, anyways with all the vibration issues, etc... What does it cost? I'm supprised there isn't a compatible bearing. Does anyone know the diameter of the bearing journal of the drive shaft at the carrier bearing? If there's something available it wouldn't have to bolt up to the car. That can be adapted. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2020 Share Posted November 2, 2020 With your power level and being lifted wouldn't it be better to just replace all of it? Staked in u-joints and all that business - with a stronger single piece that can be serviced? Haven't done one since pre-covid. Back then a single piece custom unit was generally $550 to $750. About what Subaru used to charge for the complete driveshaft assembly (the only way they sold them). GD Quote Link to comment Share on other sites More sharing options...
kanurys Posted November 2, 2020 Author Share Posted November 2, 2020 (edited) That seems about right from my own research. Thank you for the advice. I agree about the staked in u-joints and increased power handling. With our remote location (Durango, CO), it's hard to find a decent driveline shop. I'll explore the options of a custom single piece shaft as well as replacing the carrier bearing and post back. Edited November 2, 2020 by kanurys Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted November 3, 2020 Share Posted November 3, 2020 While tinkering with Impreza tailshaft I found 2009? Mitsubishi RWD not 4WD Triton ute in Australia uses a cheap centre bearing in a carrier that should work with EJ size bearings, just you'd need to make carrier brackets fit, but after that - readily available swap in bits if you had Impreza tailshaft Quote Link to comment Share on other sites More sharing options...
kanurys Posted November 3, 2020 Author Share Posted November 3, 2020 10 hours ago, Step-a-toe said: While tinkering with Impreza tailshaft I found 2009? Mitsubishi RWD not 4WD Triton ute in Australia uses a cheap centre bearing in a carrier that should work with EJ size bearings, just you'd need to make carrier brackets fit, but after that - readily available swap in bits if you had Impreza tailshaft Thanks for the information. I'm not sure EJ shafts are compatible with EA shafts. Anyone know about this? Quote Link to comment Share on other sites More sharing options...
kanurys Posted November 3, 2020 Author Share Posted November 3, 2020 My other thought was to pull the shaft assembly, shim the bearing housing and pour 3M window weld to make a poly bushing in place. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 4, 2020 Share Posted November 4, 2020 No you would want actual urethane not that 3M crap. https://www.amazon.com/Smooth-Vytaflex-Urethane-Making-Rubber/dp/B01MYH05WV GD Quote Link to comment Share on other sites More sharing options...
kanurys Posted November 4, 2020 Author Share Posted November 4, 2020 Gotchya. Thanks. I did further research and came to the same conclusion. Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted November 5, 2020 Share Posted November 5, 2020 On 11/4/2020 at 12:53 AM, kanurys said: Thanks for the information. I'm not sure EJ shafts are compatible with EA shafts. Anyone know about this? Not interswappable Quote Link to comment Share on other sites More sharing options...
kanurys Posted March 3, 2022 Author Share Posted March 3, 2022 (edited) Just following up on how this had held up. I casted the center bearing with the stuff GD linked to (Smooth-On Vytaflex 60 Urethane). It worked great! I've 4wheeled it and have driven it for a while and I'm very happy. If I were to make any other type of Urethane bushings I would use a more hard durometer like 80 or more, but for this center bearing it is perfect. Also, I made proper spacers for the mount to the body. Edited March 3, 2022 by kanurys 1 Quote Link to comment Share on other sites More sharing options...
kanurys Posted September 20, 2022 Author Share Posted September 20, 2022 Here's a pic of the bushing plus better, bigger spacers. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 20, 2022 Share Posted September 20, 2022 Nice work. Yeah for suspension bushings you would want something stiffer. The carrier mounts were always real soft which is why I suggested 60. GD 1 Quote Link to comment Share on other sites More sharing options...
Steptoe's photos Posted September 20, 2022 Share Posted September 20, 2022 The brackets - are these due to a lift you have ? Now, I am curious as to how you applied the urethane in order to preserve the joint. Thanks for coming back with a follow up and pics Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted October 8, 2022 Share Posted October 8, 2022 On 9/20/2022 at 3:18 AM, Steptoe's photos said: The brackets - are these due to a lift you have ? Now, I am curious as to how you applied the urethane in order to preserve the joint. Thanks for coming back with a follow up and pics First post says 4 inch lift and EJ swap. 1 Quote Link to comment Share on other sites More sharing options...
newmexguy Posted October 16, 2022 Share Posted October 16, 2022 (edited) Looked at my three shaft assemblies - that have that carrier bushing. 1. one front unit is "shorter" with good bushing and bad front U joint (guessing five speed?) 2. next front unit is "longer" with good bushing and good front U joint (Auto?) 3. Third Unit is complete assembly, long front shaft, has good U joints (has Subaru Sticker, may be replacement assembly) I did buy it from a Yard, perhaps a Decade ago, as a complete driveshaft assembly Had these loose, for so long, forgot which is Auto and which is Five Speed Edited October 16, 2022 by newmexguy Quote Link to comment Share on other sites More sharing options...
kanurys Posted April 10, 2023 Author Share Posted April 10, 2023 Just following up: The custom bushing is doing fine along with the drop brackets. I'd recommend going this before you need to so that the stock bushing never tears. 1 Quote Link to comment Share on other sites More sharing options...
kanurys Posted April 20, 2023 Author Share Posted April 20, 2023 On 9/20/2022 at 1:18 AM, Steptoe's photos said: The brackets - are these due to a lift you have ? Now, I am curious as to how you applied the urethane in order to preserve the joint. Thanks for coming back with a follow up and pics I pulled the shaft, put the whole assembly vertically in my bench vise, taped off any cracks and openings in the torn rubber and poured poly urethane in that vertical position. I had one leak so things got a little messy, but it was slow enough that it cured before too much leaked out. 1 Quote Link to comment Share on other sites More sharing options...
Peerson Posted Sunday at 01:45 PM Share Posted Sunday at 01:45 PM On 9/19/2022 at 8:56 PM, kanurys said: Here's a pic of the bushing plus better, bigger spacers. Those spacers are sick! Custom? How long are they? Running a 1990 Loyale on a 4" lift and EJ22. My center bushing wasn't as torn as yours, but was noticing some problems, so filled with the Vytaflex 60. However upon reinstallation, there is massive vibration. Fairly certain it's due to my spacers being too short. Any suggestions for spacers would be appreciated! At one point even ran the bearing upside down with spacers to get a little more clearance, but still don't think it's enough. Quote Link to comment Share on other sites More sharing options...
