Skubaskott Posted November 29, 2020 Share Posted November 29, 2020 Hey guys I am in the process of my build and I need to get bolts for the adaptor plate. Has anyone used an adf adapter plate. And if so what length bolts did you get? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 2, 2020 Share Posted December 2, 2020 You need to have two bolts welded together so there offset. Screw one end into the engine, slide the adaptor plate in place then fit the gearbox. You should have enough meat on the lower studs to leave them as is. I’m surprised your adaptor plate doesn’t come with the required bolts. My mate makes them over here and he supplies modified bolts welded by a certified welder (which is required for engineering certification). Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 2, 2020 Share Posted December 2, 2020 8 hours ago, el_freddo said: You need to have two bolts welded together so there offset. Screw one end into the engine, slide the adaptor plate in place then fit the gearbox. You should have enough meat on the lower studs to leave them as is. I’m surprised your adaptor plate doesn’t come with the required bolts. My mate makes them over here and he supplies modified bolts welded by a certified welder (which is required for engineering certification). Cheers Bennie You should be required to declare this fact each time you suggest EJ implant Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 2, 2020 Share Posted December 2, 2020 (edited) 9 hours ago, el_freddo said: You need to have two bolts welded together so there offset. Screw one end into the engine, slide the adaptor plate in place then fit the gearbox. You should have enough meat on the lower studs to leave them as is. I’m surprised your adaptor plate doesn’t come with the required bolts. My mate makes them over here and he supplies modified bolts welded by a certified welder (which is required for engineering certification). Cheers Bennie I've seen that done, but every plate I've used had holes tapped into it and bolts threaded into the plate. You drill out the threads in the engine, and then bolt the plate on. I just looked at the ADF page, it says right there it's 3/8-16. Just a matter of measuring the thicknesses and adding it up. https://awdadventure.com/collections/ea82/products/ea-ej-adapter-plate Edit: based on the picture, it looks like the SJR one comes with smaller diameter studs, so you don't have to drill out the threads in the block. https://www.sjrlift.com/collections/engine-swap/products/ej-to-ea-engine-adapter-engine-swap-sjr-ej22-into-ea82 Edited December 2, 2020 by Numbchux Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 3, 2020 Share Posted December 3, 2020 Thanks @Numbchux I didn’t know they were made like that. Engineers over here wouldn’t approve that if the plate is alloy, steel maybe. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 3, 2020 Share Posted December 3, 2020 (edited) Yea, steel is a must, I think. Edited December 3, 2020 by Numbchux Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 4, 2020 Share Posted December 4, 2020 On 12/3/2020 at 8:21 AM, Step-a-toe said: You should be required to declare this fact each time you suggest EJ implant Depends on how you go about it. I’m not into adaptor plates but know a bit about them. And if someone goes for an EJ swap, some research should be part of this decision! I guess not everyone does this bit before diving in head first. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Ionstorm66 Posted December 7, 2020 Share Posted December 7, 2020 Kind of odd to require a steel plate to attach two aluminum parts together. As long as there is enough thickness for proper thread engagement. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted December 7, 2020 Share Posted December 7, 2020 Problem is the threads overlap or are very close to it. Two threaded holes about three mm apart would be a whole lot stronger. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Numbchux Posted December 7, 2020 Share Posted December 7, 2020 14 hours ago, Ionstorm66 said: Kind of odd to require a steel plate to attach two aluminum parts together. As long as there is enough thickness for proper thread engagement. It's only ~1/2" thick. The threads in the block are much deeper than that. Maybe Aluminum would work, but I feel better with it being steel. Quote Link to comment Share on other sites More sharing options...
