1 Lucky Texan Posted September 9, 2022 Share Posted September 9, 2022 So I bought a 3M rubber wheel gadget to attempt removing the old cracked clear bra from my car. I have seen 3-4 videos and everyone seems to recommend a different solvent/cleaner to use to clean off adhesive residue. Wondering who's done this or something similar and what did you use? I'm attracted to the suggestion of 90% Isopropyl alcohol if there's no downside but, will it really work? Quote Link to comment Share on other sites More sharing options...
heartless Posted September 9, 2022 Share Posted September 9, 2022 with enough elbow grease, yes it does work.. The one that i like is Goof-off - BUT - try it in an inconspicuous area first to be sure it wont damage the paint... like in the spare tire well, maybe? also make sure you are well ventilated.. it does have a strong smell I personally have not had any problems with it damaging paint, but always best to make sure. Goof-Off will cut thru sticky residue from just about anything. also works well fro removing tar splatters, and other icky things. There is another called Goo-Gone, but that does not work nearly as well imho. Quote Link to comment Share on other sites More sharing options...
jonathan909 Posted September 9, 2022 Share Posted September 9, 2022 Yeah, all adhesives are different and you have to experiment a lot. I used to love Freon TF for just about everything, but those days are long gone. So the "inconspicuous area" rule rules. Acetone, any citrus-based cleaner, isopropanol, and my new favourite, 95% ethanol - Everclear. Now that the border's open again, I've been getting the 1.75 litre bottles duty-free for $20 - way cheaper than isopropyl, and you can drink it! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 10, 2022 Author Share Posted September 10, 2022 concerned about acetone as I will be near the front bumper. I have some citrus (limonene) on hand. Iso is cheap and handy enough to have around...may try those 2 before buying anything to specialized (read; expensive) lol 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 11, 2022 Share Posted September 11, 2022 Probably too small and tedious of a procedure for a bra and a curved surface but I’d look into heat and razor. There’s a few options: Prolonged direct sunlight, heat gun, plastic razors or metal razors. I’ve had some adhesives peal off surprisingly easy (relative to how bad I thought it would be) with copious heat. Quote Link to comment Share on other sites More sharing options...
moosens Posted September 11, 2022 Share Posted September 11, 2022 Getting the widget was not a loss. I am currently battling a 79 wagon that was tucked away in 1981 and for some reason put on jackstands in 89 and somewhere in that period the previous owner had taped the windows , etc and proceeded to primer grey paint half the car or so. There’s more but for now we are all concerned with tape residue or adhesive, same deal, which has been in for way too long. Granted my car is an extreme example. But I’ve had huge success with the razor. Much much much less success with various household type solutions etc. Brand G as well. Just didn’t cut it. Working on metal I also found that using some Noxon metal polish the previous owner left with some other cleaning items, worked really well too. Try the solutions but don’t toss that razor. Quote Link to comment Share on other sites More sharing options...
azdave Posted September 12, 2022 Share Posted September 12, 2022 Have you tried a steamer like used for wall paper removal? I was quite pleased how it helped take off the 30 year old window tint and residue on my 87 DL. I found a used steamer at a garage sale. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 13, 2022 Author Share Posted September 13, 2022 I do own a steamer, but just not crazy about the scraping. Seems like a slow-ish approach. Need to find a plastic scraper I guess.... one guy said to idle the car, that gets some heat onto the hood. at least one method can be a back-up for the other. Quote Link to comment Share on other sites More sharing options...
moosens Posted September 14, 2022 Share Posted September 14, 2022 Yes I also used plastic scrapers where I was concerned. Quote Link to comment Share on other sites More sharing options...
