After brake job, electronic parking brake set, idiot lights ALL lit up, car immobile
Posted (edited)
Hi Everyone.
I am tired. My 2018 Outback was in the garage for three days and I am doing the work, and I am too old for this BS. I replaced both rear CV axles, both hubs, both rotors and the brake pads. The goal was to correct a grinding sound in the rear. One brake pad was worn to the steel, but otherwise would be quite. I think the noise is from worn bearings after 98,000 miles.
As a tangent - I could NOT remove the hubs from the knuckles on the car, and eventually removed the knuckles entirely and took them to a machine shop to be separated. It took them over an hour on each knuckle to part them - paid $240. Once the knuckles were removed, replacing the axles was a no brainer. The frozen hubs cost me a lot of time on the hoist.
When the repairs were complete, the parking brake was locked, and the Outback would not go forward or backward. I friend was near (long story) who had experience in this, and we removed both rear tires, removed two small bolts, and removed the 'motor gear unit', exposing a star pattern stub. He turned this and released the parking brake pressure, and on the hoist, both rear wheels spun freely. I drove home, but unfortunately all the nasty indicator lights on the dashboard were on, including "Brake", and "Park" indicator lights.
I got home - car drove fine if you didn't look at the dashboard.
I unplugged the negative battery terminal and left it overnight. After a good 16 hours I started the car. It would drive forward and back, and the Brake light was not illuminated. I thought 'good', we are making progress. While the Brake indicator light was off, many other systems such as Eye Sight were NOT engaged, and all those warning lights are ON.
I pulled up on the electronic brake handle, which had been off (not illuminated or the brake set), and pulled it up to set the electronic brake. It set the brake, making the Outback immobile, and now it will NOT reset to release the parking brake.
In summary of the current situation: New brakes, pads, bearings and CV axles. Outback electronic emergency / parking brake engaged, and the car is immobile. Neutral battery terminal off. When driven to house from garage, all the major systems were disengaged, but the car drove normally. I didn't try it, but I am sure cruise control would not engage with all these indicator lights on.
So, how can I correct this ? At this point it looms a pretty significant problem, hopefully one of you mechanics can help.
I do have an OBD reader and can reset some codes. I have not looked at that yet.
What do you think smart people? I need the car now and am at a loss.
Thanks, Craig.
PS: I am saving you a lot of reading by skipping over significant parts of this story line. What I did write is accurate and to the point.
Edited by craigmcd
  • craigmcd changed the title to After brake job, electronic parking brake set, idiot lights ALL lit up, car immobile
I purchased a Gearwrench scanner tool (GWSMARTBT) for $145. It promises to reset the Electronic Brake System. After that I should be able to clear the codes and dismiss all the warning lights on the instrument cluster. If not, then I will have to remove the EBS gear units, loosen the parking brake tension, and drive the car to a Subaru mechanic with the professional scanner.  Worst brake job ever.
Edited by craigmcd
I don't know for sure but suspect eyesight equipped vehicles need this step.  I heard it's a nightmare to replace windshield glass with an eyesight system and it needs some special alignment and setup again.  Not something any windshield shop can do.
