nelstomlinson Posted Tuesday at 11:50 AM Share Posted Tuesday at 11:50 AM There are puddles of oil on top of the engine, particularly visible on the passenger side. This is the 2002 I put a new short block into about 5000 miles back. Anyone have any idea where that's coming from? Link to comment Share on other sites More sharing options...
montana tom Posted Tuesday at 01:03 PM Share Posted Tuesday at 01:03 PM oil pressure sending unit Link to comment Share on other sites More sharing options...
brus brother Posted Tuesday at 02:43 PM Share Posted Tuesday at 02:43 PM if near front ps fluid? Link to comment Share on other sites More sharing options...
bushytails Posted Tuesday at 07:17 PM Share Posted Tuesday at 07:17 PM You own a subaru. Link to comment Share on other sites More sharing options...
nvu Posted Tuesday at 07:48 PM Share Posted Tuesday at 07:48 PM Other places to check. If near the rear passenger, check the pcv hoses. If turbo, theres a middle block nipple that likes to leak when the clamps weaken from heat. Link to comment Share on other sites More sharing options...
nelstomlinson Posted Wednesday at 11:18 PM Author Share Posted Wednesday at 11:18 PM No turbo, thank God. @montana tom, where's the oil pressure sender? Is that near the front, a little to the passenger side of the middle? Link to comment Share on other sites More sharing options...
montana tom Posted yesterday at 01:24 AM Share Posted yesterday at 01:24 AM Near the front, on top, on the pass side. Between the alternator and the power steering pump. Is this motor oil or perhaps it is power steering fluid? Link to comment Share on other sites More sharing options...
nelstomlinson Posted 20 hours ago Author Share Posted 20 hours ago It's definitely motor oil. I looked closely at that sensor, and I can see oil bubbling out of it. It must be bad if my old eyes can see it. NAPA calls that an oil pressure switch, and they should get it in today or tomorrow. Oddly, NAPA specs say it's a 2-7psi switch. I guess that means it closes somewhere between 2 and 7PSI? or maybe closes at two, re-opens at 7? That seems WAY low. If I put a proper gauge there, what would it read? Link to comment Share on other sites More sharing options...
bushytails Posted 15 hours ago Share Posted 15 hours ago It'd read somewhere between 2 and 100. I remember when ford fixed complaints of low oil pressure by replacing the gauge sender with a switch and resistor, so the gauge always read 2/3rds from 2psi up... Link to comment Share on other sites More sharing options...
