Why is there oil on top of the engine?
It's definitely motor oil. I looked closely at that sensor, and I can see oil bubbling out of it. It must be bad if my old eyes can see it.
NAPA calls that an oil pressure switch, and they should get it in today or tomorrow. Oddly, NAPA specs say it's a 2-7psi switch. I guess that means it closes somewhere between 2 and 7PSI? or maybe closes at two, re-opens at 7? That seems WAY low.
If I put a proper gauge there, what would it read?
  • Like 1
15 hours ago, bushytails said:
It'd read somewhere between 2 and 100.  :)
I remember when ford fixed complaints of low oil pressure by replacing the gauge sender with a switch and resistor, so the gauge always read 2/3rds from 2psi up...
Apparently in the ‘60s ppl wanted their V8 fords to be capable of “high revs”. Apparently the kids back then liked to see over 4000 rpm on the tacho, but the engines didn’t like it so apparently Ford modified the tacho so it looked like the engine would rev that hard when in fact it was still within what Ford considered safe operating.
There’s always a way around things. It’s also why modern temp gauges don’t move once “at temp” until something catastrophic occurs and it sky rockets.
Cheers
Bennie
It's a basic idiot light switch.
I keep them in stock, and I routinely replace them when a car comes in for other work.
Subi's are extremely forgiving about running low on oil, but when that light starts flickering or worse yet, stays lit, you need to check things out.
I changed out the sender, cleaned the oil off the top of the engine as best I could, and took the dog for a ride. So far so good, that may have been the only leak. I got this one from the local Napa, I'll get a couple more coming via mail order.
Thanks, all!
