nelstomlinson Posted Tuesday at 11:50 AM Share Posted Tuesday at 11:50 AM There are puddles of oil on top of the engine, particularly visible on the passenger side. This is the 2002 I put a new short block into about 5000 miles back. Anyone have any idea where that's coming from? Link to comment Share on other sites More sharing options...
montana tom Posted Tuesday at 01:03 PM Share Posted Tuesday at 01:03 PM oil pressure sending unit Link to comment Share on other sites More sharing options...
brus brother Posted Tuesday at 02:43 PM Share Posted Tuesday at 02:43 PM if near front ps fluid? Link to comment Share on other sites More sharing options...
bushytails Posted Tuesday at 07:17 PM Share Posted Tuesday at 07:17 PM You own a subaru. Link to comment Share on other sites More sharing options...
nvu Posted Tuesday at 07:48 PM Share Posted Tuesday at 07:48 PM Other places to check. If near the rear passenger, check the pcv hoses. If turbo, theres a middle block nipple that likes to leak when the clamps weaken from heat. Link to comment Share on other sites More sharing options...
nelstomlinson Posted Wednesday at 11:18 PM Author Share Posted Wednesday at 11:18 PM No turbo, thank God. @montana tom, where's the oil pressure sender? Is that near the front, a little to the passenger side of the middle? Link to comment Share on other sites More sharing options...
montana tom Posted Thursday at 01:24 AM Share Posted Thursday at 01:24 AM Near the front, on top, on the pass side. Between the alternator and the power steering pump. Is this motor oil or perhaps it is power steering fluid? Link to comment Share on other sites More sharing options...
nelstomlinson Posted Thursday at 01:47 PM Author Share Posted Thursday at 01:47 PM It's definitely motor oil. I looked closely at that sensor, and I can see oil bubbling out of it. It must be bad if my old eyes can see it. NAPA calls that an oil pressure switch, and they should get it in today or tomorrow. Oddly, NAPA specs say it's a 2-7psi switch. I guess that means it closes somewhere between 2 and 7PSI? or maybe closes at two, re-opens at 7? That seems WAY low. If I put a proper gauge there, what would it read? 1 Link to comment Share on other sites More sharing options...
bushytails Posted Thursday at 07:00 PM Share Posted Thursday at 07:00 PM It'd read somewhere between 2 and 100. I remember when ford fixed complaints of low oil pressure by replacing the gauge sender with a switch and resistor, so the gauge always read 2/3rds from 2psi up... 1 Link to comment Share on other sites More sharing options...
el_freddo Posted Friday at 10:32 AM Share Posted Friday at 10:32 AM 15 hours ago, bushytails said: It'd read somewhere between 2 and 100. I remember when ford fixed complaints of low oil pressure by replacing the gauge sender with a switch and resistor, so the gauge always read 2/3rds from 2psi up... Apparently in the ‘60s ppl wanted their V8 fords to be capable of “high revs”. Apparently the kids back then liked to see over 4000 rpm on the tacho, but the engines didn’t like it so apparently Ford modified the tacho so it looked like the engine would rev that hard when in fact it was still within what Ford considered safe operating. There’s always a way around things. It’s also why modern temp gauges don’t move once “at temp” until something catastrophic occurs and it sky rockets. Cheers Bennie Link to comment Share on other sites More sharing options...
montana tom Posted Friday at 11:50 AM Share Posted Friday at 11:50 AM It's a basic idiot light switch. I keep them in stock, and I routinely replace them when a car comes in for other work. Subi's are extremely forgiving about running low on oil, but when that light starts flickering or worse yet, stays lit, you need to check things out. Link to comment Share on other sites More sharing options...
nelstomlinson Posted Saturday at 02:55 AM Author Share Posted Saturday at 02:55 AM I changed out the sender, cleaned the oil off the top of the engine as best I could, and took the dog for a ride. So far so good, that may have been the only leak. I got this one from the local Napa, I'll get a couple more coming via mail order. Thanks, all! 2 Link to comment Share on other sites More sharing options...
