April 8Apr 8 im pulling the engine trans and diff from a part car and sending the car off to the yard. i dont want to lay under the car and manipulate the transmission down. will it come out the top still bolted to the engine? 2001 legacy sedan Edited April 8Apr 8 by sirtokesalot
April 8Apr 8 Yes it can. But the angle can be quite extreme. Better way to do it is separate the gearbox from the engine and pull them out from the top individually. You’ll spend quite a bit of time under the car disconnecting mounts, driveshafts, wiring etc. Remove the gearbox crossmember to give more room if going for the one piece removal.
April 8Apr 8 I've pulled them attached. Yes the angle is significant. The other way to do it is to drop it out the bottom. The cross member and trans mount will unbolt. Raise the car or lower the cross member/engine-trans.
April 8Apr 8 Sometimes if it’s possible I’ll cut away the radiator support. Part car going to tue yard would be a candidate. Hey you’re in CT too, right ? Which yard(s) are you dealing with these days?
April 9Apr 9 Author i do not have a lift im honestly not opposed to cutting the subframe and radiator support ither. as far as junk yards not many left. chuck and eddies is prety much the last pick and pull i know of. boyds in norwich will still give a good price on a stripped out car. there wont be much left in this one thats still good. the driveline was the only good part of the car.
April 9Apr 9 Author well i started i opted to just unbolt the trans and pull em seperatly. stripping a car is so much quicker when you dont care about the car the parts are coming out of. Edited April 9Apr 9 by sirtokesalot
April 9Apr 9 Author 3 hours start to finish engine trans diff driveshaft axles mirrors ecu tcu fuel pump radiator and condensor out. nothing els worth keeping. and thats including driving it out of the woods and cleanup time. Edited April 9Apr 9 by sirtokesalot
4 hours ago4 hr I know you've already done it. But when I scrap cars, I cut out the radiator support. Then the engine and transmission come out easy.I even made the upper radiator support bolt-in on my 4Runner during the engine swap. I had the V8, 4-speed auto and transfer case in and out of it several times, but left it all as an assembly.
1 hour ago1 hr You guys got a v8 4Runner as standard, or is that an engine conversion? We got the v6 or the diesel option, definitely no v8!
