September 3, 200421 yr That's right folks -I just aquired a 94 Legacy GT wagon. "Dark side" as it's dark blue metalic. Don't know bout all this, first venture into the land of the "new and improved" sure wish it was a turbo but tis good for getting my feet wet so to speak. Has some issues and some crash rash but the price was right and the potential is there so -- I took the plunge. Basic questions 1) can I get a FSM or are they hens teeth, give your first born stuff? 2) needs the head lamp plastic de fogged, will plexiglass polish work? 3) Has 185/70 14" tires/wheels, just so happen to have a set of 225/50 16" tires/wheelsfrom my Impreza sitting here wonder if they'll fit? 4) ABS light is on - how do I pull the error codes from the ABS brain? 5) see "Has anyone been foolish enough to..." post Thanks for reading this and see ya in the trenches.
September 3, 200421 yr Pretty wagon, I'll see if I can answer some of teh questions. 1) They are available, the problem is that in 93 Subaru started using big binders and annual updates, so you would have to get the 93 binder(s) and teh 94 binder(s) to have a complete set. 2) Not sure here, but sounds good. 3) Yep, they will fit. 4) Haven't played with ABS so I don't have a clue here. 5) There are kits out there to put low pressure turbos on these engines, I wouldn't put the EA82 turbo on there since it is a high pressure turbo. I know people will argue with me about this, but I just rely on my almost 40 years of turbo experience and just grin.
September 3, 200421 yr 2) needs the head lamp plastic de fogged, will plexiglass polish work? Might sound strange but if you just use some good ol turtle wax on them and buff it off should take the foggness right off. Always has worked on wifes 94.
September 3, 200421 yr 4) ABS light is on - how do I pull the error codes from the ABS brain? Under the passenger seat is the box with red led that flashes out the error codes. When I had a 92 LS the problem with the ABS was the leaky sunroof let too much water on the passenger side floor and light would go on. Driving with the carpet up for a few days would dry it out enough for the light to go out. I think I got the key to the flashes from chilton's. 16 flashes before repeating was ABS code? Good Luck
September 3, 200421 yr You can paruse what fsm scans I have on my site. I have a complete 92 section for the engine & engine electrical on there. They will be pretty much the same for the 94's http://www.main.experiencetherave.com:8080/subaru_manual_scans headlamp cleaning....this is the more permanent fix http://bbs.legacycentral.org/viewtopic.php?t=739 abs diag procedure http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/absdiag.jpg I'd recommend checking out the legacycentral bbs. A LOT of info on the first gen legacies www.bbs.legacycentral.org
September 3, 200421 yr HI SKIP and Welcome to the "DARK SIDE" Frightning huh???? Was for me too... so to speak.... Kind of like when I first got my computer and joined the 20th centry... Again Welcome... Vicky
September 3, 200421 yr hey there for the FSM try this http://techinfo.subaru.com You pay 19.00 or so for 72 hours of access and download to your hearts content. All files are PDF. BW
September 3, 200421 yr I recently picked up a 1st gen Legacy as well ('91 Turbo), but I was already on the "dark side" having owned my Impreza long before I got the RX. (to Legacy777): Thanks for the headlamp fix link, I was wondering that myself as the headlamps on my 91 Turbo are quite yellowed. I've searched the crap out of Legacy Central for various things about this car already, but hadn't seen that post yet.
September 3, 200421 yr there unfortunately isn't any fsm info for the first gen legacies on the subaru techinfo site. also...fixed the link... warp, you're welcome....that's going to be the only permenant fix...all the polishes and such leave the plastic open to the air to just oxidize again.
September 3, 200421 yr 2) needs the head lamp plastic de fogged, will plexiglass polish work? I have the same problem on my Outback...I was just going to use some Windex or some other cleaner...but i'll try the Turtle Wax. Good luck on your new wagon!
September 4, 200421 yr Might sound strange but if you just use some good ol turtle wax on them and buff it off should take the foggness right off. Always has worked on wifes 94.So does toothpaste if they're foggy, not full of moisture.
September 4, 200421 yr Skip, I say leave the wagon as stock as you can. 94 GT wagons are very rare, about as rare as a GL-10 Touring Wagon.
September 4, 200421 yr Author Hey Guys, thanks for all the great replies. Leg 777 your site is killer. It turns out to be a GT touring wagon, has the raised section of the roof like the GL TW's. Runs real good needs a few items (center console, steering col. surround, ect) will be contacting some of you for the nessasary bits. Once again, thanks for all the info - being a neophyte -I/we (Dark Side and I) appreciate it. BTW I updated the picture in my first post
September 4, 200421 yr Skip our cars are Twins. I have a 94 GT as well but I put WRX wheels on mine. Same color too.
September 4, 200421 yr Touring wagon refers only to the turboed ones. but it's cool. Yours is more rare. I've never seen a GT in person before. if you need stock parts but cant find any, i'm more than willing to pick up a few from carter(they've got all sorts of crazy old stuff) and ship them over for you
September 5, 200421 yr Pretty wagon, I'll see if I can answer some of teh questions. I know people will argue with me about this, but I just rely on my almost 40 years of turbo experience and just grin. Did they really make turbos back then in the dark ages?
September 5, 200421 yr Skip, glad to see you posting again. I've missed your wisdom on the old school cars. Good luck with the Legacy.
September 5, 200421 yr Did they really make turbos back then in the dark ages? You should know Ed, you were there ages before I was.
