November 1, 200421 yr Does this sound/look feasible to you guys? 87 4wd D/R EA82 SPFI Wagon Build 4"/3" Lift 30x9.50 BFG M/T on 15x7 IFS Toyota Rims (Tires currently measure 28.5" Diamter unmounted) Redrill hubs for 6 lugs OBA using York 210 in stock is location Bob 9-12" off butt Custom Bumpers with portable 2500 LB ATV Winch mount Rock Sliders Front Half Doors Heres a quick photo chop of what I was thinking. I borrowed the picture for the gallery and I forgot who it was...Sorry.
November 1, 200421 yr Author Looks like a good plan to me! what about welding the diff or lsd? I'm still unsure on that one. I will probably go LSD because I don't like the idea of swapping an axle in to go wheeling even though I know welding performs way better. But it would be pretty easy to just solid axle the rear and keep the lift low.
November 1, 200421 yr Something needs to be done back there. I just did some very light wheeling and these rigs could really benefit from a locker of some kind. I wonder how close a sammi axle is? I've got a friends with some extra's laying around. They already have lockers in them.
November 1, 200421 yr put a hoop bar at back of front seat and half door the rears also, why should the driver get the all the good views.
November 1, 200421 yr Author I wonder how close a sammi axle is? I've got a friends with some extra's laying around. They already have lockers in them. I think you would need a 4wd toy axle since its 6 lug and already has correct bolt circle. Sami only have a 5 lug. And nissan/datsun axles are really expensive to get gears and lockers for...... does anyone know if the XT6 5 lug bolt pattern is the same as a Sami (5 on 5.5") or Ranger (5 on 4.5") Bolt pattern??
November 1, 200421 yr Author If I did decide to half door the rear doors then I think i would like to do something like this ....... Half doors are realy pretty easy to make but they do take a lot of time since the sheetmetal welding is usually corner to corner. and sicne they are right infront of you, its hard to cut corners because you will see all the little defects in the body work. Guess I found my new avatar...
November 1, 200421 yr well some datsun 2wd 720s came with 3.9 gears so that would be the axle to find to match the gears in the subaru front diff. Im not sure if there are any samurais or toyota axles that come stock with 3.9 gears.
November 1, 200421 yr Author well some datsun 2wd 720s came with 3.9 gears so that would be the axle to find to match the gears in the subaru front diff. Im not sure if there are any samurais or toyota axles that come stock with 3.9 gears. 79-80 4x4 toyota had 3.90 gears! Plus 'I believe' there are the 3.73 gears that came in the 2wd 1-tons that had the 8" diffs which will swap into a 4wd housing.
November 2, 200421 yr are you really going to pull that rear end in 6-8 inches like you did in the pic?? if so that would be cool. it looks stouter and meaner, it would also be a lot better for wheeling. thats all i have no thoughts on the differential. Tyler J.
November 2, 200421 yr Not to say it cant be done, but you have your work cut out for you on bobbing a wagon. I've seen your custom cab Toyota though and think you could do it if you take your time and dont cut corners. If you want to, do it, dont let anyone stop you, its your car!
November 2, 200421 yr Author Yes my plan is to basically make a long wheel base 4 door hatch back..... Should be sweet. A york 210 is the biggest "York" full size Air compressor that people use to make engine driven On Board Air systems that are belt driven off the engine. For more info read here..... http://www.onboardair.com Here is the one I installed on my 2wd pre-runner. http://www.pirate4x4.com/forum/showthread.php?t=168115&highlight=york
November 2, 200421 yr Author My 4runner is bobb'd 9" My 2wd is stretched 13" on the cab and then the what use to be long bed is cut down 13" inteh front and 20" off the back. so as for the work involved, I think it should be pretty easy. I think the hardest part will be just the bondo work to make it look factory. Thats where you can really confuse people!
November 2, 200421 yr all the body lines are pretty straight in the back, I dont think it would be any more work than bobbing a 4runner. im not sure how far from the back the gas tank sits but there must be close to a foot you could cut out before you hit it.
November 2, 200421 yr do it, it looks killer. shortening those rear 1/4 windows will be a pain, maybe use plastic/canvas Jeep style half doors and windows?
November 2, 200421 yr Author For the windows I think I will just make some new ones out of some thin plexglass and glue them them. For the doors I will just have two sets..... One for the road and one for wheeling. but hopefully I can come up with something to make the half doors kinda weather proof with a removable canvas......
November 2, 200421 yr with half doors your exposing yourself to the elements anyways, lose the windows weld in stretched metal and keep a couple pieces of plexiglass handy that are cut to size for winter then just zip tie in like a tranny cooler add-on or even use some thumb screws, put some foam or weatherstrip around edge to seal out the wind and rain and snow and mud and well you get the picture. Gotta say the bobwagon looks pretty sweet.
November 2, 200421 yr and as long as your lightening up and opening up, take another hatch, take out backglass and cut down into lower portion and cap off like your half door then just use some netting like those tailgate thingys.it'll definitly be breezy on the way home but what the hay its all good.
November 11, 200421 yr Author Well heres what I got to work with and the progress I've made so far...... Oh if I do Bob it I figured I can take up to 13" pretty easy and then I will have to rebadge it as a Stubaru..... Picture 1, its a 87 SPFI D/R 5 speed wagon. Pretty bad shape on the inside but its got the drivetrain I wanted. Also the engine needs to be sealed up because I hate leaking cars! Picture 2, Its a 85 with no engine or tranny but its has good interior and adjustable struts. So its just a donor part car. Picture 3, what the interior looked like after I removed the seats? Yuck.... Nothing a little elbow grease and cleaners can't handle. BTW I even found a black film canister with some old weed flakes in it. :-\ Picture 4, Carpet and rear seats installed!
November 11, 200421 yr sweet man, i love it when a plan comes together.i would be interested in coming down to oregon and learning a few tricks next summer.i'll bring the brat,it will be kickin it live by then....got some friends down there i need to see anyway,maybe i can make some new friends .can't wait to see it bobbed.
November 11, 200421 yr BTW I even found a black film canister with some old weed flakes in it. :-\ it looses it potency after a few years from what i understand<J/K>
November 11, 200421 yr Author Picture 5, Front seats installed and cleaned up. Also the center console. I foud out that Castrol Super Clean also works awesome on the interior..... Picture 6, Then to swap out the dash pads I had to remove everything out of the dash. What a PITA!!!!! That made for a long night. Picture 7, But the finished product was well worth it. No all I need to do is get a real stereo in there and get my CB installed. It actually turned out better than I expected. I also got a change to actually drive it a bit but I need to find those oil leaks pronto because it apear to be dripping onto the exhaust and burning off. What a freak'n mess. I'm Soooo tempted to just pull the engine and reseal it but I haven't totally deiceded yet. I still need to get my previous project sold so I can devote the garage to this project and have some CASH to work with. Anybody want to buy my 83 Toyota xtra cab?
November 17, 200421 yr Rick, Looks like an awesome project!....Can you help me out with 3 questions... 1. Does the Castrol Super Clean cut the tar like junk used under the carpets? 2. What type of welding are you doing on your auto sheet metal projects, and can you give any hints...TIG, MIG, pulsing? 3. What kind of welding rod seems to work well with Japanese auto sheet metal (Subaru if you have gotten that far) in your experience? Thanks very much! Here on the east coast we have to battle body rust, and I am about ready to start cutting and welding!
