November 8, 200421 yr So yesterday I bent a few lift blocks: Both sides are equally bent, but the rest of the x-member bolts/blocks are still ok. The round bumper sucked up most of the hit, although that long 19mm bolt is prolly bent too. You can pretty much watch it happen in this video. As far as I can tell, this foward most rear lift block is pretty much useless, can I remove the block/steel plate and just run a bolt through the round bumper part? Hopefully the body threads aren't too hosed.... Also, it seems I might be able to cut the round part down 1/2" or so [for clearance], and stick a slightly shorter bolt in there. I dunno exactly how the bumper works, but it seems that the inner steel cylinder [inside the bumper] is connected to the rest of the bumper via ribs running the length of the piece, if I cut it down, the cyclinder should still "float" [be attached] in the bumber ok, right? Anyone else tried this? Anyway, removing the foward block is my biggest concern. I notice the EA81's, while similar, don't have this sort of thing ahead of the crossmember. Which makes me think i can pull it. Here's another pic, the stuff I wanna remove is red, the place I wanna cut is blue.
November 8, 200421 yr Well, I know nothing of your question, but let me say nice video, and good work in screwing up your lift in less than a few weeks (?) of putting it in!!!!
November 8, 200421 yr Author good work in screwing up your lift in less than a few weeks (?) of putting it in!!!! For what its worth the car still drives fine (straight too), but is definetly bent.
November 8, 200421 yr wow that was impressive. as for your question I would try to straighten it as best as possible and reinforce that point. if your going to wheel your roo thaty hard you may want to consider some full belly skid plates. no actual experience fixing that type of damage on a roo here sorry.
November 8, 200421 yr my bet is that both the bolts and blocks are fine, and what you did was totally screw the unibody where the captive nuts are held.
November 8, 200421 yr Author my bet is that both the bolts and blocks are fine, and what you did was totally screw the unibody where the captive nuts are held. Well, sure. But only at the front block is the body tweaked. The rubber bumper mount it OK, the bolt looks to be bent if anything. That bolt is like 6" off the body at its head, so it got tweaked somewhere along the length of it. No big deal. The two front-rear (or is that rear-front?) blocks are a liability. Can I remove them?
November 8, 200421 yr I would say no. I'm not running them (actually they are there but in my case not doing anything significant, since the body they bolt to is rusted out at that point) but my other blocks are welded together with 2x2 square tube to keep them from folding under.
November 8, 200421 yr Author I would say no. Ok, what about this. The only thing I see that block/plate doing is preventing the the top [edit: bottom] of the rubber bumper from flexing. So I was think I could get a machine shop to make a a nice piece of heavish gauge steel in a sorta z-bend, that would still support the bumper while actually sliding over rocks instead of digging into them. It'd prolly be easier to get such a piece to mate to my now-mangled body. (It's rusty anyway) I'm thinking like this: Also, how bout cutting the round part down a bit? If it doesn't compromise the bumper, it would make mounting a piece of "z" steel alot easier,also improve clearance. Don't wanna start hitting the driveshaft though...
November 8, 200421 yr that would make sense to me. as I found with other types of lift kits. just droping the stock components is not always the best thing. sometimes you need to do you own modifications to keep it solid.
November 8, 200421 yr My first time out with the Hatch Patrol I bent those same blocks. After bending and straightening them a handful of times, I decided to try and fix it. I got together with a fabricator friend (same guy who made my bumper) and we came up with this solution: This is the best picture I have of it at the moment, i'll get soem more if needed. This piece started life as a pice of aluminium channel. The open space between the sides was a touch larger than the width of that block. First think we did was drill the 3 holes that are in the bottom plate, as this piece was goign to replace it. Once we got those drilled and it bolted in, we took measurements on where to cut the sides and to bend it. We then cut the sides off (as seen above) and bent it accordingly so that we had a nice flap to bolt to the floor. We then drilled 2 holes in this flap for the bolts to go through the floor. On the inside we used a small rectangel of aluminium to act as a washer plate for these bolts. I now affectionaly call these my Custom Side Skids. At this same time we thru-bolted a lot of the major suspension components using threaded rod, and large washers made out of aluminium (really 4"x4" square/round pieces) for the inside of the body. There were 4 major spots we thru-bolted. On the front trailing arm plates we did the block that also supports the tranny crossmember. In the back we did the major one through the round thing with the rubber bushings. Let me know if you need pictures of any of this, I will do my best to get them!
November 8, 200421 yr What Subarutex had done was exactly the same thought I had about 'fixing' that issue. I don't play around on rocks and such hard surfaces so I havent bent mine yet. I did notice right away while putting them in that would be an issue. Putting in those little skids there should really help. Make sure they are tough enough to withstand you slaming them into rock!
November 8, 200421 yr Talk to Tex, he had "skid plates" built for those blocks. They're pretty exposed.
November 8, 200421 yr Author Let me know if you need pictures of any of this, I will do my best to get them! I knew you'd have something to say about this, thanks. More pics would be great, if you can get um. Any tips on straightening the body?
November 8, 200421 yr Any tips on straightening the body? Assuming you are meaning straightening those blocks, I'll explain how I did it the 4 times before I decided to make the skids. Remove the 2 bolts going through the block. Remove the block. Take the stock bolt (use the stock one, so you don't have to take off the lower plate, the less you remove the faster it goes), and thread it into the nut. It was my findings that what bent was the capture nut of these bolting locations and a tiny bit of material around it. So by threading a bolt into the nut (without the block) you are able to bend the capture nut back into place. I just did it by hand. There should have been enough play in the third major bolt that it did not bend, just the front two. So reassembly should be relatively easy. Slide block into place and reinsert longer hardware. At this step it may be beneficial to loosen the third bolt a tiny bit to give slack to the lower plate to help line up the front block. Hope that helps!
November 8, 200421 yr Author Assuming you are meaning straightening those blocks, I'll explain how I did it the 4 times before I decided to make the skids. It helps, thanks. This is pretty much what I was thinking, although my version used alot more hammer . So, now I'm thinking one good heavy piece of steel like 4" or 5" wide drilled to replace the plate, then bending just ahead of the flimsy block down to the body. Maybe some countersunk harware so it'll slide... So you just bolted yers to the foot well of the back seat? And then some more steel (or Al) under the nuts/heads to re-enforce?
November 8, 200421 yr I did use a piece of aluminium on the inside as a sort of washer plate. Its all under the carpet and discreet. The front of my skids are not countersunk or anything. I've thought about modifying it, but so far, hasn't proven to be a problem.
