March 12, 200521 yr I had a new clutch installed on my 86 gl. It slips going up steep hills.I brought to my mechanic . He adjusted it. It still slips.He said I burned up the clutch. It has 500 miles on it. One thing I did was to disconnect the hill holder.I did not ride the clutch. Could a Subaru clutch glaze over in 500 mile even if I rode it all the time? Could the pressure plate be rebuilt and be defective. It sounds like he is going to try to get out of fixing it. The reason i got the new clutch was that the old one was slipping. Any ideas on this one? Thanks, Abcus
March 12, 200521 yr If you disconnect the hill holder, you must put a spring on the clutch fork so it can return to its 'parked' position when the clutch is out. Without that return spring, its possible that there was enough constant pressure to damage the clutch over the course of 500 miles. Thats the info I got when I did my 5 speed/no hillholder conversion..
March 12, 200521 yr no that wont make a clutch wear out in 500 miles. I drove my car for 2 months with the hill holder disconnected, and the return spring disconnected. The mechanic got oil on the pressure plate or the clutch disc. That would make it slip and burn up. Its his fault.
March 12, 200521 yr Was the rear main seal replaced, along with the new clutch? Did the mech. change the pressure plate or just the clutch disk? Did he turn the Flywheel? All of the above could be factor, of your problem.
March 12, 200521 yr i agree, lack of return spring wont hurt a thing. i drove all summer without one, on a used clutch. mechanic screwed up, and he probably cant think of why, so he blamed it on you.
March 13, 200521 yr Author Thanks all for the help. He replaced the engine seal. He machined the flywheel.He replaced the pressure plate.I do not know if the pressure plate he put in was rebuilt or new. I read the fine print in the warranty and in says under no circumstances will slippage be covered by the warranty.The job was bid at $395 and cost $650 by the time he got thru with me.If the pressure plate was a bad rebuilt one maybe I could argue about that. He claimed that the clutch for a 1800 cc engine cost more than a 1600 by $100. Is there any difference in the clutch between those two engines? I called a parts house and they said no. Is there any way I can find out if the pressure plate is defective without opening the bell housing again? Thanks again, Abcus
March 13, 200521 yr yes there is a difference. the 1600 uses a 7 1/2 inch disc. EA81 uses 8 inch and EA82 uses something likea 8 1/2 or 9 inch disc. A rebuilt kit for a EA81 is 135 bucks A rebuilt kit for a EA82 is 185 bucks That comes with pressure plate, clutch disc, alignment tool and pilot bearing. I almost guarentee he got oil on the clutch disc. If he did everything he said he did, that'd be the only way it'd do that, unless the disc came from the factory like that.
March 13, 200521 yr Some ea81s also use the 9 inch - '83 onward i think. I agree that he must have got oil on the clutch, you'd have to try pretty hard to burn out a clutch in 500 miles if it were good.
March 13, 200521 yr Is the clutch properly adjusted? If the clutch is misadjusted it will slip, should have it readjusted by someone more knowledgible. I would get a return spring on the set-up and see if that helps, though it can cause pre-mature wearing of the clutch, it is totally unlikely that happened in 500 miles Unless there is oil leaking from the crank seal, or front seal on the transmission, there is no way he got any oil on the new clutch. You need to go back and ask him if you take it someplace else, and they find that he installed it incorrectly or the clutch disk is in new condition, is he going to rebate you the money you paid to him? It is also a two stage flywheel meaning any machining done on the one surface has to be done on the other, otherwise, there will be no resistence and it will slip.
March 13, 200521 yr Also find out if he used thread sealant on the flywheel bolts. Without it oil can seep through the threads and get on the flywheel side of the clutch disc. The threaded holes go completely through the crank and are exposed to the oil from the crankcase. There is also another possiblity. When turning the flywheel there are two specs for the 1800 for flywheel depth. OHC and OHV have two different specs and the difference will enable the new clutch to slip and to not be adjustable.
March 13, 200521 yr Also find out if he used thread sealant on the flywheel bolts. Without it oil can seep through the threads and get on the flywheel side of the clutch disc. The threaded holes go completely through the crank and are exposed to the oil from the crankcase. Interesting - I did not know that - I'll remember it the next time I do my clutch
March 13, 200521 yr I would contact BUREAU OF AUTOMOTIVE REPAIR TOLL FREE TELEPHONE: 800-952-5210 MONDAY THRU FRIDAY http://www.smogcheck.ca.gov/StdPage.asp?Body=/GenInfo/FactSheets/BAR_Enforcement.htm
March 13, 200521 yr If you machine the surface the pressure plate bolts to more than the friction surface, will you get better grip? I'm having problems visualizing the "step" that the PP bolts to. Is it higher that the friction surface, or lower? Which way would you machine it to increase clamping force? And yes, I tried search.
March 14, 200521 yr If you machine the surface the pressure plate bolts to more than the friction surface, will you get better grip? I'm having problems visualizing the "step" that the PP bolts to. Is it higher that the friction surface, or lower? Which way would you machine it to increase clamping force? And yes, I tried search.The center of a ea82 flywheel where the clutch disk and Pressure plate gripping face sets, is recessed about 3/4" below the surface that the P/P bolts too the flywheel. The clutch is only going to grab as much as the springs in the P/P are rated for. Grinding the suface of the flywheel where the P/P bolts only, might give you a little more pressure, but it may make the clutch unable to release because of coil bind inside the P/P.
March 14, 200521 yr Can heavier springs be installed in the pressure plate? Mabe I should wait until I take my tranny off the engine to figure out how it all works. My clutch knowledge is fuzzy at best. I know that there are fingers that the throwout bearing pushes in that compress the pressure plate springs, but I don't know what they pivot on.
March 14, 200521 yr Can heavier springs be installed in the pressure plate? Mabe I should wait until I take my tranny off the engine to figure out how it all works. My clutch knowledge is fuzzy at best. I know that there are fingers that the throwout bearing pushes in that compress the pressure plate springs, but I don't know what they pivot on.That is not a real option. Your best bet is buying a HD or performence clutch set. From Ram clutch, Exedy, Act or another Man..
March 14, 200521 yr It is possible that they screwed up the machining and ground more off the center portion of the flywheel where the disk mates up than where the pressure plate bolts on. That could definitely result in slippage. Like Qman said, I would also ask if he used sealant on the flywheel bolts. If even a tiny amount of oil leaked past there, OR if he put too much grease on the input shaft, the disk could have gotten lubed up and started slipping.
March 15, 200521 yr I am having a similar issue on my Brat... finally got back from vacation so I am finally gonna try to REALLY get it solved. My money on both this car AND mine is that the flywheel is turned incorrectly. The part where the disk mates was probably turned down, but the outside (where the teeth and stuff are) probably was not.
