September 17, 200520 yr I was doing some cleaning in the wagon and after carpet removal I found a piece of the metal floor had been factory threaded. It was pretty prominent too, raised above the rest of the floor. Any ideas what it is for? I was thinking it might be an alternative place for the spare tire but the bolt that holds the spare down is too long.
September 17, 200520 yr I think it might be for securing a full-size spare. On my turbo wagon, you couldn't (according to the manual) fit the 185/70R13 tire under the hood. Instead, you put it in the back and used the hold-down.
September 17, 200520 yr I think it's where you're supposed to secure the flat tire after you change it.
September 17, 200520 yr Where exactly is this nut located I always have a full size spare in the back and it would be nice to secure it down.
September 17, 200520 yr Author In my wagon, it isn't a nut, just a threaded peice of thick metal. If you remove the carpet totally, it should be behind the driver's seat, next to the plastic wheel well cover.
September 17, 200520 yr i found some weird things on the interior of my 88 gl hatch. right above the floor in front of the back seat there's a little plastic knock-out cover thing, and underneath there is a threaded hole with no apparent purpose. one on both the driver's and passenger's side.
September 17, 200520 yr yep...place to store the flat, there's a different mounting bracket/bolt that woks with it. 2 of my wagons came with it. still in it's little plastic bags, here's the instructions on it... How to store Flat Tire 1. Screw the shaft into the floor through the slit in the mat covering the trunk floor (or luggage space floor). Rotate the shaft in a clockwise direction by spanner until it is tight. (Make sure that the mat is not caught.) 2. Pass the shaft through any one of the lug holes in the wheel and tighten the wheel down with the holder until it is fully secure.
September 18, 200520 yr Author i found some weird things on the interior of my 88 gl hatch. right above the floor in front of the back seat there's a little plastic knock-out cover thing, and underneath there is a threaded hole with no apparent purpose. one on both the driver's and passenger's side. Ya, I found one of those too. Only found one it on the passenger side though. I have absolutely no clue what they are for. They couldn't possibly be another spare/flat holder? Anyone?
September 18, 200520 yr i never knew thxnow i wish i hadent thrown it away or is it in the garage nm my problem l8r
September 18, 200520 yr Ya, I found one of those too. Only found one it on the passenger side though. I have absolutely no clue what they are for. They couldn't possibly be another spare/flat holder? Anyone? My guess would be that it is the securing point for car seat anchors.. Thats what my 90 wagon owners manual said anyway. I even had the little bolt/anchor pieces that threaded in there
