MAJOR brake problem... (after install)
Well I just finished the front brake install on my '78 and I have a big time problem...
I got the brakes all bleed, that worked fine, have decent brake pressure.
BUT when the car moves, its like a metal ochestra under my front wheels... MAJOR grinding. I know its because its new pads, and a new rotor and theres not alot of space there, but how in the heck can this be fixed or what is the problem??? Im totally clueless...
I've changed the brakes on a bunch of cars, and I have NEVER had grinding noises afterwards. Before, sometimes, but that's what backing metal on rotor sounds like, and that's why the brake job happened.
Jack the front up, rotate the tires, and figure out what's causing it.
-=Russ=-
Check your e-brake, it might be on a little.
Its not on, I gave it several yanks several times to be sure.
The pads seem to be right, unless they have too much material, they are metal masters.
I spun both brakes with the wheels off, they both do it, but one more than another.
