September 25, 200322 yr My CFO, has given the nod of approvail for the purchase of a Weber carb for the '82. What info do I need to give them when I order the carb, other than it's for a OHC 1.8L Subaru engine? Thanks in advance for the input. I be a Happy Camper now!!!!....
September 25, 200322 yr pretty much, just that it's an EA82. The only thing that changes between engine models is the adapter I think.
September 25, 200322 yr Do you mean your car is an EA-82 or a 1982 IF its a 1982 than its a pushrod EA-81 1.8L - Erik Hosa - Tacoma, WA -
September 25, 200322 yr I didn't even pay attention to the '82, I saw he said OHC (overhead cam) and the only engine with that is the EA82, but if his car actually is an '82 with an '82 engine... then yeah, it's an EA81 pushrod.
September 25, 200322 yr Hes the one with the 82 Brat with the ea82 engine in it. All that matters is that you get the right intake manifold adapter which would be an ea82 hitachi.
September 26, 200322 yr Author So, I need to order a Weber carb with the Hitachi adapter kit for the EA-82 engine?! I take it that the carb will already be properly jetted and such, yes/no?! Now for that Accel Super Stock coil and plug re-gap, already have 7mm solid core plug wires on her. Guess I should be getting a new heater core and shut-off valve for it also, starting to get chilly here in the early AM......
September 26, 200322 yr If you buy your Weber from a shop that gets them from Redline, then the carb should be jetted about right for the engine you tell them it's going on. And it should be a genuine new Weber not a ripoff copy or reman used (as apparently some shops are selling.) Note that the guys at Redline say that some fine tuning of the jets might be needed due to minor differences from one engine to the next (of otherwise identical engines.) But so far, I think everyone here has been happy with the jets Redline installed.
September 26, 200322 yr Author Total kewlness!! Ordering from carbsunlimited.com, so I should be all set in that department. Can hardly wait either, she's getting tempermental as all get out with these cool mornings. Just plain don't want to run 'till she warms up a bit. Thanks for all the info, guys.....
September 26, 200322 yr That is too funny - I originally typed out the message ending "unless you have dropped and EA-82 into an EA-81 car" but I decided to leave it out assuming it would confuse more than help. I now know who TomRHere is - recognize his name/EA-82 Brat from the yahoo brat club (I'm chevyguy22) Have fun with your weber - that puppy should move - Erik Hosa - Tacoma, WA -
September 27, 200322 yr Author Well, I ordered it today. Also went ahead and ordered me some tranny and engine mounts for it. Tim,... I've read about the inconsistancies with the kits. Bolt holes not quite right, wrong bolts, not fitting the opening of the manifold exactlly, so on and so forth. I'm prepared for that stuff. Don't have power steering, so that's no problem there. My linkage has already been modded to fit the EA-82 engine and carb, so we'll see what's up there. Bratwerst,... Oh I'm hoping she moves with the Weber. She didn't do to bad with the Hitachi, before it went south on me. Had it's querks, but she'd go when you hit the go pedal. Or should I say loud pedal, as Skip does, 'cause the duals do like to talk when you mash the pedal. Kewl to see another member of the BRAT club on this board, I know of one other, possibly two, on here that's a regular of both sites. I don't have to many different handles. Hard enough to keep track of passwords, let alone what one goes to which name. Getting to old to remember to much stuff.....
September 27, 200322 yr I don't know if there's two or more factories maikinf these, but all 4 I've installed worked perfect. The one I have on my hatch right now is awesome. After a week of sitting, in the morning time, I can start it right up, kick it down, and drive away with no problems. As if it were fuel injected or something. . . Lots of power to boot.
September 27, 200322 yr I got my redline weber from bow-wow and installed it without trouble! I had to tune it a little, but it started up right when i bolted it on!
September 27, 200322 yr my bolt holes for the adapter were too big, and not counter sunk... and the waterjacket that goes up into the stock carb, didnt get blocked like it sould by my adapter, so i had to use some sealant... not too troublesom though, for an adapter.
September 27, 200322 yr There does seem to be some difference in adapter plates. I've had three styles, all for the EA81. Out of those it was the one distributed by EMPI (through Bow Wow) that fit the Hitachi intake best. One adapter I got from a guy for $5 because two of the bolt holes hadn't been spotfaced for the cap screws. It's sick how much they charge for these adapters...just cheap castings with a few holes and flats.
September 28, 200322 yr Author http://www.carbsunlimited.com/Weber/Dataresults3.asp?Kit_Nbr=K731&Model=ALL%20,%20INCLUDING%20BRAT That be where I ordered mine from..............
October 1, 200322 yr Author Tranny and engine mounts arrived yesterday. Carb is sitting in Illinios this AM. It should be sitting where it belongs, not in Illinios. She's really getting difficult to drive now, I need that carb, Real pain to keep her running when first started, choke never did work right, but I could hold it at a fast idle for a few minutes, and be on my way. Now, it's crank crank crank, cough cough spit sputter spit cough die, crank cough spit sputter sputter sputter. Then she'll stay running , well, maybe. Having to do the heel-toe bit on the gas and brakes is a pain, 'specially thru town with all the stop lights and stop signs. I need my Weber!!!!!!!..........
October 1, 200322 yr I happen to have one of these little guys laying around. Actually, it is bolted to the intake of a '78 LUV that my g/f's brother left at my house. I'm gonna steal it and send the truck to the wrecking yard.
October 1, 200322 yr Where did you get your tranny and engine mounts Tom? And how much were they? Places I've seen want a damn fortune for them. GD
October 2, 200322 yr Author buyasianparts.com is where I got them from. Eng mnt = $78.41 ea., tran mnt = $33.90 ea. Must say that the eng mnts are for the EA-82, and the tran mnts are for the EA-81 4spd. Always fun mixing up parts orders that way, had lots of experience over the years. Had me some genuine Frankenstien vehicles.....
