Wagons only - post your pictures here!
... I cut the round 9004 socket from an old set of broken plastic headlights from an unknown car the junkyard let me have and I dremmel'd the tail light socket bigger and JB welded the 9004 Twist lock socket part to the back of my tail lights. I bought 9004 pigtails from Napa for like a dollar each and wired it up to high only. Stepped up to a bigger fuse and it worked for years. It eventually half melted the reverse section of tail light because it got to hot one night but I got over it.
Thank you for your Kind Answer.
My Subaru "BumbleBeast" also has Halogens for the Reverse Lights, but I use the Bulb that you can see in the Following Photo...
...marked as "Halogen" ... it came with the 1156 Base already, and the Box said that it also will melt the Plastic if it is Lit for more than three Minutes.
Kind Regards.
  • 2 weeks later...
  • Replies 304
  • Views 55.1k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
My 1997 OBS. Just shy of 250k on the body.
Engine:
1998 EJ25D block
Mahle bearings
NPR rings
Balanced rods and pistons
EJ22E heads; port matched
Cometic hybrid HGS
Delta 220 cams
Grimmspeed Phenolic spacers
NGK plugs and wires
PageOne Customs grounding kit
eBay oil catch can
PageOne Customs UEL header
Invidia replica exhaust
Drivetrain:
Exedy KSB04 clutch kit
Uncle Scotty's cocktail fluids
Group N pitchstop
Kartboy shifter bushings
PageOne Customs shortshifter
Suspension:
KYB Excel G struts
2004 STi springs
Paranoid Fabrications 3/8" rear saggy butt spacers
WRX rear sway bar
WRX sedan rear lateral links*
Wheels/Brakes:
2005 WRX 16x6.5 rims
Accelera Alpha 205/60/16 tires
2002 WRX disc swap*
WRX master cylinder and PV swap*
Interior:
2003 WRX seats front and rear.
Pioneer head unit and door speakers
(2) OEM underseat subwoofers
ProSport oil pressure gauge
WRX Momo steering wheel*
WRX pedal covers
WRX map lights*
(*= bought but not yet installed)
Newest race build project. Testing race Frankenmotor in the dunes.
2" strut spacer lift, 205/75R15 Toyo Open Country A/T
Paint, cage, custom bumpers to follow...
