April 6, 200620 yr So the Brat has been acting funny lately, I think due to driving through some water on the last run we did. When driving in 1st through 3rd gears, if I more than feather the gas, the car acts like it's out of fuel or has water in the exhaust, and goes whooooop whooooop, and so on and so forth. It stumbles real bad. It also doesn't seem to rev any. It takes me forever to get going more than 15 mph in 1st and 25-30 in second. It idles fine (very high, but fine) but as soon as I start driving the problem starts. Any ideas on what's wrong?
April 6, 200620 yr Doubt the water we drove through last weekend would make it act like this, expecially 3 days later. Might need to perform one of daves "italian tune ups". Could have gotten some gunk in the carburator. And yes... the idle on your brat is alittle high ;-) -Brian oh, and when was the last time you changed the fuel filters? That could cause a problem like this.
April 6, 200620 yr Sounds fuel related. I can check it out tomorrow when you get off work. Let me know.
April 6, 200620 yr If you spray your coolant out yer tailpipe, and have oil in yer radiator, ya blew a gasket of thy head. Done a few of those.
April 6, 200620 yr If you spray your coolant out yer tailpipe, and have oil in yer radiator, ya blew a gasket of thy head. Done a few of those. I think he meant water coming from a deep puddle, stream etc. not out of the engine....lol
April 6, 200620 yr Yeah, definatly sounds fuel related. I doubt its anything like a blown headgasket tho Check your filters and for the heck of it spray some carb cleaner around the base of your carb. Check for any leaking carb or manifold gaskets. I would also try the italian tune up. -Brian
April 6, 200620 yr I second changing the fuel filters...both of them. When was the last time they were changed. I had a wagon, took it on the sand days after I bought it and didn't check all the connections and such to the carb. The air cleaner came loose and needless to say I sucked some sand into my engine. Yeah...it was a fun trip home. I would hold the gas steady and it would go...stumble...go...stumble...go...stumble...go...stumble... top speed was 45mph on a 65 mile trip. I changed the fuel filters and BAM! gone. From then on, all my engines have been sealed up and the only thing allowed in is regulated fuel and air.
April 6, 200620 yr I hear those Itailians also like to pour auto trans fluid down there carbs, give it a good clean out.
April 6, 200620 yr i guess this is EA81 which i know nothing about. but water under the distributor would be something to consider as well.
April 6, 200620 yr Author Thanks guys. I bought 2 fuel filters last night, replaced the one under the hood and will change the one near the fuel pump today. I also changed the air filter as well. I also noticed last night after the car started making a horrible clicking noise that I have to replace the driver's side axle too. Guess water didn't help that any. Thanks again, I'll keep ya informed.
April 6, 200620 yr I hear those Itailians also like to pour auto trans fluid down there carbs, give it a good clean out. Phizinza's got it. Instead of Auto Trans Fluid, I use MMO (marvels Mystery Oil) or some seafoam. Rev the motor to about 2500rpm and dump about 1/4 qt. into the carb... let the carb choke, but keep the motor alive. Do that about 2 or 3 times. -Brian
