trying to explain the change in my car
Clutch went out on my Loyale. Got to the point that just by hitting the gas too hard the clutch would slip. It wasn't too bad to replace. I could actually bend the old disk with my fingers it was so thin. New disk has been working fine. Definitly go for the kit if you are doing it yourself and make sure it comes with the pilot and throwout bearings.
  • Replies 71
  • Views 4.5k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
City: Minneapolis
State: Minnesota
Vehicles: 96' Legacy Brighton
Re: trying to explain the change in my car
Before you shell out $500 for clutch, make sure there's no easy fix. Check fluid in clutch cylinder, check that there is some freeplay of clutch pedal.>>what do you mean by free play?
You should be able to push the pedal down at least a little ways before the hydraulic cylinders kick in to move the release fork. If you have no freeplay it could be that your clutch isn't having the full amount of force applied to it when you let off of the pedal. You should be able to tell when the master cylinder starts to pressurize the system when you push in the clutch pedal because there is more resistance.
where is the clutch cylinder? I just went to check. I have found the brake fluid reservoir. There is s small black cylinder between the brake fluid reservoir and the windshield washer fluid reservoir. however I don't know how to get it open. does the car have to be warm in order to accurately check it?
so I just drove around the block. there seems to be a bit of freeplay. However at a stoplight I let the clutch out completely and the car slowly moved forward. still no luck finding the clutch cylinder. I'm beginning to see a worse case scenario here.
Here's a pic for you, from 99 Factory service manual. For reference - on the right is a side of brake booster - round thing attached to the firewall.
Are there any US MB ers nearby who will volunteer to help her check this out? If she was in CA i'd have a look for her? Sounds like clutch time to me and a good mechanic she can trust would be in order.
I am not a woman just not a car buff. though if there were suggestions in the area I'd be happy to entertain them.
no problem the help is greatly appreciated.
any thoughts on how long an aging clutch can last? is cold weather much of a factor? will my car ultimately not move? what is the outlook?
is a better course to replace the clutch or sell the car?
replace the clutch. This is wear item on any car. Any car with a stick will need this changed eventually. Selling the car because of a worn clutch is as silly as selling it cause it needs tires.
nipper
Get some quotes and place that clutch. Eventually, and sooner than later, it will leave you standing on the side of the road.
Steve
a few more diagnostic questions....?
If when I down shift the car clearly seizes might that be an indication of low clutch fluid?
also
what I've identified as the clutch cylinder does not appear to be a screw off cap. it has two or three hoses going into it. should that be the case?
also I have not noticed any sort of smell. I can be in fifth gear at about 60 mph with a bit of acceleration and no changing gears I still get revving. <<just an observation.
can someone with a stick please post a pic of the location of the clutch master cylinder?
nipper
that would be helpful as my car did not come with an owners manual.
I kind of got shafted when I bought this as they didn't tell me it was prior salvaged. I took it in for alignment shortly after buying it and was informed the sub frame was cracked. long story
if not email me at nipper.dawg@gmail .com and i can send you a few scans.
nipper
nipper
Didn't I post a FSM scan on last page? :)
show off. i was thinking something from a wider angle. Remeber we have a total novice here :)
nipper
don't suppose his clutch is cable instead of hydraulic?
nipper
98 should be hydraulic, but since its a rebuild who knows.
nipper
