April 21, 200719 yr This is the official thread of the "My coupe is running" thread. Like it says, she runs, not totally driveable yet but it will be in a few more hours to working on it. Currently its running a stock SPFI I got from DrKrazy to replace the blown SPFI engine it had. I also swapped the FWD 3AT to a RX FT4WD d/r 5-speed, stage 2 clutch, full 5-lug setup and a bunch of other things. I still have to swap out the pedal boxes and tidy up the interior but I also swapped the instrument cluster for one from an RX as well. Also got my nifty ebay melon shooter on it as well. Gotta replace the radiator with my brand new 2 core with dual electric fans and some small items like that but it'll make it to Washington from Wyoming no problem.
April 22, 200719 yr good my car blew its intake manifold gasket again. that would be the 4th time its happened, and i use a real torque wrench when i put it in.
April 22, 200719 yr This is the official thread of the "My coupe is running" thread. Like it says, she runs, not totally driveable yet but it will be in a few more hours to working on it. Currently its running a stock SPFI I got from DrKrazy to replace the blown SPFI engine it had. I also swapped the FWD 3AT to a RX FT4WD d/r 5-speed, stage 2 clutch, full 5-lug setup and a bunch of other things. I still have to swap out the pedal boxes and tidy up the interior but I also swapped the instrument cluster for one from an RX as well. Also got my nifty ebay melon shooter on it as well. Gotta replace the radiator with my brand new 2 core with dual electric fans and some small items like that but it'll make it to Washington from Wyoming no problem. i give it a week till it runs outta oil and explodes or some other russ-tastic feat,coolant you added coolant right?
April 22, 200719 yr Author yes all the fluids are topped up currently. After I get it driving, I'm going to make a few laps around town with it, give it an oil change, do it again and change the oil right before my epic journey to Washington. Yes Andy, a melon shooter. Also known as a fart cannon or other names of that nature. I put it on my 4wd exhaust cause I had to swap them for the 4wd conversion so I left it on. It actually sounds pretty mellow for being a "Honda" accessory:-p
April 22, 200719 yr yes all the fluids are topped up currently. After I get it driving, I'm going to make a few laps around town with it, give it an oil change, do it again and change the oil right before my epic journey to Washington. Yes Andy, a melon shooter. Also known as a fart cannon or other names of that nature. I put it on my 4wd exhaust cause I had to swap them for the 4wd conversion so I left it on. It actually sounds pretty mellow for being a "Honda" accessory:-p you know x35 on xt6.net did somthing sililiar to this going east from texas to the dragon after a similiar build and long story short thats how roni got dorthy, get the drift?
April 22, 200719 yr you know x35 on xt6.net did somthing sililiar to this going east from texas to the dragon after a similiar build and long story short thats how roni got dorthy, get the drift? i give it a week till it runs outta oil and explodes or some other russ-tastic feat,coolant you added coolant right? Nobody has worse luck than you Jeff, we all know it:lol: Your just jealous:Flame: See you when you get here Russ...
April 22, 200719 yr Nobody has worse luck than you Jeff, we all know it:lol: Your just jealous:Flame: See you when you get here Russ... jealouse of russ? no i actually get to go places in my car with out a tow vehical infront of it
April 22, 200719 yr Just because your newest car has been running for 3mo without breaking down doesnt mean you get to pick on others that are having problems. Cause you know it might come back to bite you:rolleyes:
April 22, 200719 yr jealouse of russ?no i actually get to go places in my car with out a tow vehical infront of it Jeff please lay off of Russ until he makes it to Washington. Thats a long drive and any bad karma he can avoid before the trip is probably appreciated.
April 22, 200719 yr Get it fully together and driving Russ...gotta get down here for at least one more meet before you take off back to PNW. Glad to hear that engine did ya good and keeping it stock for the long haul will keep ya safe and solid .
April 22, 200719 yr Author Jeff please lay off of Russ until he makes it to Washington. Thats a long drive and any bad karma he can avoid before the trip is probably appreciated. Thanks Shawn. All I gotta do is remind Jeff about the tranny for his SVX and how I helped him out with it, both finacially and physically... Keith, that engine puuuuurs like a kitten. I had a brand new OEM oilpump and some newer timing belts and got it all put together Friday night, then today, I finished up a few little things I didn't have time to get finished the night before. I still need to put a timing light on it to get it where it should be but the engine is done minus an oil change before I leave. I still got a few small items to take care of but a friend of mine is currently in need to get some stuff done on his '91 K1500 before he moves back to Cali. He decided to break his leg while riding his dirtbike so he's a little immobile... So my car might have to take a break for a couple days since he's leaving on Tuesday but after that, its full steam ahead... again:rolleyes:
April 22, 200719 yr Hey, I made it from NH to WY in a car in much worse shape than this coupe sounds like, so I think you'll be fine. It's a pity I won't see it when I drive out to WY again this summer, but it sounds like a nice coupe. Always have had a soft spot for those...
April 22, 200719 yr Author Hey, I made it from NH to WY in a car in much worse shape than this coupe sounds like, so I think you'll be fine. It's a pity I won't see it when I drive out to WY again this summer, but it sounds like a nice coupe. Always have had a soft spot for those... There's still one in a yard here, exactly like mine was FWD 3AT and he wants $300 IIRC.... Maroon with a brown interior I think... Ace Salvage in south Laramie, just south of the interstate.
April 22, 200719 yr Jeff please lay off of Russ until he makes it to Washington. Thats a long drive and any bad karma he can avoid before the trip is probably appreciated. sry i'll quit, russ good luck
April 22, 200719 yr Thanks Shawn. All I gotta do is remind Jeff about the tranny for his SVX and how I helped him out with it, both finacially and physically... i still owe you for that you know
April 22, 200719 yr Just because your newest car has been running for 3mo without breaking down doesnt mean you get to pick on others that are having problems.Cause you know it might come back to bite you:rolleyes: i felt i owed russ a beating after this thread, http://www.xt6.net/forum/viewtopic.php?t=7316 i'll lay off sry didn't mean to offend
April 23, 200719 yr Author i felt i owed russ a beating after this thread, http://www.xt6.net/forum/viewtopic.php?t=7316 i'll lay off sry didn't mean to offend Jeff, IIRC, you were the one that told me when I was takign them that I should post them. I posted them all right:-p Got more work done on the coupe today. Got the dash back together and got my pedal box in and clutch cable adjusted. Now I gotta make sure everything is nice and tight underneath, get some new exhaust gaskets and finish up some suspension/brake/tire/alignment work.
April 23, 200719 yr Author The first couple pics in KingBobDole's thread. Silver coupe is mine, white RX is his. http://www.ultimatesubaru.org/forum/showthread.php?t=74011 Then some of the mods I've done to the car in my post over in the Retrofitting forum. http://www.ultimatesubaru.org/forum/showthread.php?t=72743 I have more pics and a nice vid of the car running but I haven't had time to get them uploaded yet. Maybe later this week after I get it closer to being driveable.
