Spark plug gap for EJ22
I've got a new set of plugs here to go in the 22. What I want to know is what should I set the gap too? They are just cheapo NGK's. I've heard 0.035". But when looking at the spark off the coil pack which is a good 2/3 of an inch long I was wondering if a wider gap could be beneficial? I ran both 0.055" and 0.035" and saw no difference with my EA81 and it's Mallory Pro Master coil.
Plug gap should be between .039 and .043 I always set mine to .045 on the guage.
  • 11 years later...
11 years later...just wondering why .045 when you just said it should be between .039 and .043?
Cheers!
.02: the wider the gap the better the combustion. From HERE:
Quote
Gap: Gap has a lot to do with igniteability. The bigger the gap, the better combustion. HOWEVER, this comes at a cost. The bigger gap requires MORE voltage to spark, puting a much higher strain on your ignition system. With a turbo charged motor, the gap is usually smaller. This is due to the fact that higher cylinder pressures make it harder for the plug to fire, therby increasing voltage requirments (this is why 2.5L NA is 0.044" gap and the 2.5L turbois 0.030" gap). Can your ignition system handle the increased load?? Good question.
So, run the widest gap you can that doesn't cause issues - knock,  etc.
Remember the MFG recommends what works for all their vehicles and commonly available fuel....doesn't mean it's optimum for YOUR car.
Edited by wtdash
Cheers!
If I remembered my reasoning from over a decade ago I'd surely tell you.
I could tell you why I swapped an ej22 into my L series over a decade ago! Still goes great too.
My spark gaps are set by the recommended spark plug for the 22 as per the manufacturer's parts catalogue.
Cheers
Bennie
Lol, fair enough!
I bought the NGK BKR6E-11 plugs, which are actually the recommended plugs from the factory service manual (I just recently downloaded). And yea the FSM recommends a gap between .039 and .043.
I checked the NGK's gaps with feeler gauges and they are all at .042 dead on. I don't think I'll bother trying to gap them one more thousandth, but maybe.
Cheers ya'll
