Justy ECVT
So,
Once upon a time I read: "In fact, if it weren't for synthesized lubricants-and their ability to withstand high temperatures-modern jet aircraft engines simply wouldn't exist."
So, fast foreward. The Justy ECVT simply "loves" Mobile 1 in the tranny.
I'm not suprised:) Long live the ECVT, with proper maintence. Yea, that'
s spelled wrong.
Later
Well the problem in the justy is the oiled part and the non oiled part. The non oiled part is the powdered clutch (and that usually the brushes).
A brave man drives a just with an ecvt.
nipper
not shure what youre point is but if you need parts there is an ecvt her in the a&a wrecking yard.98926
nipper
A JDM, "suposidly", 40,000 mile powdered clutch has my back. :) Brushes? I got two good sets.
Doug
Doug
Welp,
I didn't mention the aluminum tranny cooler and the B&M temperature gage. Enough said. All combinded, a comprehensive package for the ECVT. My work is done.
Later on
I don't watch tv, really. Work on the Subes, and life in general.
Transtar Industries sells replacement parts for the ECVT that corrects the problems that make them puke out :-)
ReallY?
All it took was "just one look" at the above link to convince me.
Saving you the click:
Transtar Partner Program
Access special partner program resources online. Login to the system with your account number and password.
* AAMCO Transmissions
* Cottman Transmissions
BOTH rip-off "specialists"
Really? Is there an echo in here:).
Just a unverified observation. I bought one 4WD ECVT that was redone to the tune of something like $1600.00 by Cottman. Supposed to have a new belt in it, etc, etc. It is toast after not too many thousand miles. I'll open it up this winter and look around. BTW, the tires on the car are oversized and don't match. I got it in "West. bu God, Virginia. Snow was flying that day, in the mountains.
Doug
  • 2 weeks later...
How hard is it to swap a 5spd 4wd into a Justy that has the ECVT?
If'n I had the complete drivetrain to go with it.
Ah, ok. Just did a quick serach (duh) and it sounds like Bratsrus did a 5spd swap into a ECVT before.
