What plug wires to get....
yeah, yeah, I know, OEM...
what I mean is.....
I've got a de-stroked and turbo'd ej25 with a ej20G intake manifold that sits up higher than at least the ej22t intake does... and my coil pack is mounted on top of the manifold...
anyway, I have a set of '97 OBW wires on it now, but there are *just* barely long enough. there is no slack in wire #4.
does anybody know if the WRX wires are longer?
I have the same issue with the 97 oem wires, and the motor uses the regular NA manifold... :rolleyes:
Anyway, the WRX wires are a bit longer so it might be worth a try.
WRX is coil on plug ignition. No wires.
The problem with the OEM wires being a little on the short side is standard on the '97's.
Magnacore are the other wires that are recommended here.
magnecor wires rock, they're great stuff. worth a call if you want an entirely new set anyway. don't know if the EJ stuff is longer, but worth a call. i think you can call magnecor directly and talk to them.
Wow, I feel very silly aboot this. :o
Mick I would suggest buying a msd build it yourself wire kit. I did that for my hatch and they are great and then you can make them whatever length you want. Usually only come in a v8 kit though. Besides you could make another and sell it.:burnout:
  • 3 weeks later...
Sell it to me!!!:Flame:
what I mean is.....
You realize that the OEM kit has a longer wire for the #4 cylinder right? I found out the hard way too!
You might need the wire set for an older JDM wrx. They had the coil on top of the intake.
