March 11, 200818 yr not sure what this noise is but i think its coming from the front underneath. it sounds like i'm dragging a chain down the road but when i look underneath there's nothing hanging down. it only does it while moving so i hope it isn't a wheel bearing or something similar.
March 11, 200818 yr Details on the car please. Can be a heat shield, if you have those kind of things, or a backing plate for a disc. nipper
March 11, 200818 yr You just ruined several od my possible answers. Can it be engine ping? Does it change when you go left or right, or in reverse? Does it change with the clutcj depressed? nipper
March 11, 200818 yr Author no change left or right, or in reverse. it sounds louder when the clutch is depressed only cuz the engine rpm's drop.
March 11, 200818 yr Check the drive belts, make sure nothing is loose there. It can be engine pping, a cv joint, aloose brake pad, or a wheel bearing. nipper
March 11, 200818 yr My brat makes a funny sound if I am off the gas. It sounds like a chain too but I know that it is a CV axle, It has done it before. You might check your motor mounts that is what mine is. the motor torques over and streches the axle out and kinda pulls the Axle apart, it doesn't break the axle but its putting the screws to it. Jeff
March 11, 200818 yr a more basic check . . . my RX was making a noise like that, it turned out to be the metal plate that backs the shifter boot (either the trans, or the d/r shifter) rattleing against the trans tunnel . . . chris
March 11, 200818 yr I'm with quidam and nipper. Get those wheels off the ground and rotate 'em. Hear a grinding sound? Rusted bent backing plate on the disc. Fix? Bend the crap out of the way and noise is gone.
March 12, 200818 yr Author I'm with quidam and nipper. Get those wheels off the ground and rotate 'em. Hear a grinding sound? Rusted bent backing plate on the disc. Fix? Bend the crap out of the way and noise is gone. hey thanks guys will definately check that out tomorrow before i head down to do some studying at the library
