people around puyallup washington
hey all im kinda in a jam with my current subaru condition the car runs like a champ but i cant get the clutch pedal to engauge the clutch so it wont shift so i was wodering if there is anyone around that might be knowledgeable on the subject an be willing to take a look at it so i can have something to drive because borrowing a tahoe to commute sucks gas like no other
you could always float the gears :P lol nah check the cable I'm thinkin thats the problem too
Just be ready. They can kinda be a bear.
Jeff
it worked before just the clutch needed replaced and thats all i did so i dont know why the cable wouldnt work now?
If the cable had snapped the clutch pedal wouldn't return after you stomp it to the floor. I still think the cable is out of adjustment.
is the clutch pedal as stiff as its supposed to be? too stiff?? or no resistance?
I had to adjust the pedal on my Starion after changing the clutch.
if it was really worn down and you put in a new one then that's what the effect would be without adjustment no able to put it in gear. (or really hard to)
yea i should have put this in the OP but the pedal feels like its not even hooked up it has no resistance at all but when i had someone push it in i could see the cable moving so idk
