August 17, 200817 yr I have a 02 Outback wagon and for some reason the park lights will not turn off, even when the car is off. The swith in the emergency brake that controls the headlights works fine. I had to remove the fuse on a recent camping trip to get the park lights to go off. Any ideas??
August 17, 200817 yr 95% chance you bumped the little rocker switch on the TOP of the steering column. Its there so you can run the lights with no keys (since the lights turn off with the ignition)
August 17, 200817 yr Look at the 4th post on this thread..... http://www.ultimatesubaru.org/forum/showthread.php?t=51554
August 17, 200817 yr +++what he said. it's called the 'virgin switch', and since this was your first time, you now know why. welcome to the party!!!
August 18, 200817 yr OK maybe subaru should consider putting the 'problem' in the owners manual because it happens often. Poor guy going so far to take out the fuse. I've installed LEDs (because when parking outside residental area you need to use park lights if your pointing against the driving direction or if you are on the road) cause from time to time i have to leave them on all night.
August 18, 200817 yr +++what he said. it's called the 'virgin switch', and since this was your first time, you now know why. welcome to the party!!! Also called the battery "kill" switch by Subaru techs as it will surely kill your battery if left on long enough... good for business...
August 18, 200817 yr OK maybe subaru should consider putting the 'problem' in the owners manual because it happens often.Poor guy going so far to take out the fuse. I've installed LEDs (because when parking outside residental area you need to use park lights if your pointing against the driving direction or if you are on the road) cause from time to time i have to leave them on all night. Actually, it is in the Owners Manual. . . But how many people actually read that anyway? For my '92, it is on page 14. Not sure about the later models :cool:
August 18, 200817 yr Actually, it is in the Owners Manual. . . But how many people actually read that anyway? For my '92, it is on page 14. Not sure about the later models :cool: What is this re-ad thing you tlak about. And isnt that there just to keep the glove box from rattling?
August 19, 200817 yr What is this re-ad thing you tlak about. And isnt that there just to keep the glove box from rattling? Gotta get me one and re add it.... my glove box is rattling.
August 19, 200817 yr Author Thanks for all of the input. I can now turn off the park when from inside the car. I guess everyone is a Virgin at least once.
August 19, 200817 yr Thanks for all of the input. I can now turn off the park when from inside the car.I guess everyone is a Virgin at least once. Got your cherry!! :banana: :clap:
August 20, 200817 yr I hit the @#%*&$% thing a month ago and it had been so long I'd completely forgotten about it took me 2 days to figure it out. I guess you can regain your virginity.
August 20, 200817 yr Closest I've come to that recently (say within the last two years) is accidentally hitting the thing in bright sun and not noticing that the parking lights were on when I left the car. I was only gon for a few hours, but it was dark enough to see the parks lights on when I got back. Luckily, I had a good battery. . .
