ChuckPT Posted December 30, 2008 Share Posted December 30, 2008 So I lost my keys to my '85 gl wagon and figured it would be more expensive and troublesome to re-key it than it may be worth, and if I can just rub two wires together to fire it up, why not. Anyone know which two wires would do the trick? (And no, I am not a car thief, even though it might appear that way) Quote Link to comment Share on other sites More sharing options...
dhise Posted December 31, 2008 Share Posted December 31, 2008 There should be an old thread to search for giving all the little details of how easy our cars are to drive off with without the keys....... Quote Link to comment Share on other sites More sharing options...
Skip Posted December 31, 2008 Share Posted December 31, 2008 (edited) how do you plan to defeat the steering wheel lock? if you are breaking out "the tools' pop the lock and use a screw driver for a key. Edited December 31, 2008 by Skip Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted December 31, 2008 Share Posted December 31, 2008 Easist thing I have found is to go into your trunk, pop the lock out of it. Take it to a locksmith, and get a key for it. Cost isnt to bad, and you now can lock your door when you get a key!! Quote Link to comment Share on other sites More sharing options...
Skip Posted December 31, 2008 Share Posted December 31, 2008 Pass side door lock tumbler has the key number on it. title to Subaru dealer - key made hot wire to coil positive and hot wire to small spade conn. on starter (removed after start) still no steering though?? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted December 31, 2008 Share Posted December 31, 2008 if your car's VIN is in the dealer database, and if you bring proof of ownership, the dealership will cut you the smoothest-working key you've ever had for an old Subaru. Quote Link to comment Share on other sites More sharing options...
bratman18 Posted December 31, 2008 Share Posted December 31, 2008 if your car's VIN is in the dealer database, and if you bring proof of ownership, the dealership will cut you the smoothest-working key you've ever had for an old Subaru. I wish my ignition still worked good. I can put any subaru key in my Brat and start it right up! It's a little worn out. It does have almost 260,000 miles on it though! Quote Link to comment Share on other sites More sharing options...
The Scooby Posted December 31, 2008 Share Posted December 31, 2008 find someone else with a subaru and borrow their spare, i would almost bet it will work, i do it all the time at work. Quote Link to comment Share on other sites More sharing options...
Turbone Posted December 31, 2008 Share Posted December 31, 2008 The easiest/ghetto way is to take a pair of channel locks and pull of the chrome ring around the lock set. The whole unit will come out now and you will be able to unlock the steering as well. Otherwise, just get the number of the inside of the passenger door lock and get a new key made. I also suggest everyone that owns a EA82 car to have a fuel cutoff switch installed Quote Link to comment Share on other sites More sharing options...
Skip Posted December 31, 2008 Share Posted December 31, 2008 Chuck, here is a real deal PM "Tailgatewagon" he lives in your town and will set you up - proper. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 31, 2008 Share Posted December 31, 2008 find someone else with a subaru and borrow their spare, i would almost bet it will work, i do it all the time at work. Also Some Keys from the 80`s and 90`s Nissan`s Should fit there too... I Went to a Locksmith to Obtain New Keys for my Subies, he Took the Back Door`s Lock out (The Less Used Key, due to the Remote electric Lockin` mechanism) and made one New Key followin` its Config, the new Key Works like Brand New in All Doors & Starter Switch... Maybe it is a Good Idea for you... Good Luck! Quote Link to comment Share on other sites More sharing options...
